#196
Re: New Talon Speed Controller
I also see that Read Status sets a timeout of 0 for messages continually transmitted, but could also do a transaction (with 10ms timeout) if requesting something on-demand. Everything else is still blocking (set parameters require Ack, read parameters are synchronous). Really, CAN is designed to never care if a message is received, and to transmit everything continuously (with less important information at a slower rate). Having an Ack message makes no sense to me. Edit: Motor Set defaults to synchronous mode, and the Isochronous input is not in the help. I'm guessing many teams still run in synchronous mode. It should default to isochronous mode, IMO. Last edited by apalrd : 12-12-2012 at 09:43 PM. Reason: looked slightly more |
#197
Is it possible to revert a Talon to factory calibration?
#198
No it is not.
#199
Mike, could it be done with a PWM signal generator which generates a known pulse width accurate to 0.001 ms ?
#200
Mike, our last Beta update included a new class for the Victor 888's. I haven't seen one for the Talon yet.
Is one going to be released? If not, what's the recommended class to use? We haven't had any problems using the victor class with it at all. |
#201
Figures. We're now one update behind because we had our seminar and didn't want to break our code by updating a day or two before the seminar. It's probably in there.
#203
A user calibration could be performed to obtain values that are are close or even the same as what's saved during initial programming. But there would be no way for the user to confirm this. We did not feel the ability to restore factory calibration was necessary since the procedure would not be much different than performing a user calibration. And a user calibration will yield the best performance. |
#204
FRC 422 just received the first 8 of our Talons! They are far smaller than we imagined them to be.
#205
Team 2410 put four on our mecanum demo robot and man do they drive like a beauty! Makes driving off of our app so much smoother and easier. Me gusta mucho.
#206
Compared to what? (also, what does "off of our app" mean?)
#207
Compared to previously having 4 victors. Off our app means we put one of the robot open shields on it and one of our programmers wrote an app too driver the demo bot off a phone with
#208
Yeah we were driving the Victors off the app as well. The Talons just seemed more responsive. I will admit it was not a blind study so maybe its just the hyper behind the Talons that makes it seem so
#210
But as you said, it would be most interesting to conduct a blind study. |
