Go to Post You can either spend lots of energy complaining about it and whining or you can try to figure out how to make a positive experience from the whole thing. - dlavery [more]
Go Back   Chief Delphi > Technical > CAD
Thread Tools Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Unread 18-12-2012, 15:19
Re: Elevator Design - Rack and Pinion Cascaded - 772
Originally Posted by akoscielski3 View Post
First off I never mentioned putting constant force springs on the elevator to eliminate almost all of the weight.
A loaded spring provides an extra source of power and changes the calculations.
the 28lbs included the outside rail, which is not being lifted at all
If the center of mass of a 28-lb assembly changes from 31" to 57" (a difference of 26"), it doesn't matter what parts move and what parts don't: it still takes 28*(26/12) foot-pounds of work. If you lift the whole assembly 26", or if you only lift half the assembly 52", it's still the same amount of work.
the mass that is being moved would be almost 0, if not positive from the springs.
The springs don't make the mass zero. They just balance the load and provide an additional source of power. The mass still has inertia.
