Go to Post I always wondered what would happen if two robots mated. - Greg Needel [more]
  #211   Spotlight this post!
Unread 18-12-2012, 16:07
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
Re: New Talon Speed Controller
I'm thinking it's probably the linearity of the Talons which made the difference you noticed.
But as you said, it would be most interesting to conduct a blind study.
That'd be what, set up a few identical drivebases and make it "impossible" to see into what controllers are on them, then have a drive drive the three and rank how well they handle?
Academic Student (Forever)
  #212   Spotlight this post!
Unread 18-12-2012, 16:23
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
To save parts and ensure there are no mechanical differences, I would use the same drive base. Build a simple electrical board for it, but leave off the speed controllers. Put the speed controllers into separate boxes (even cardboard boxes would do for this), with a wiring harness coming out of it (wired up the same way for each case, so controlling the motors is identical). Close the boxes. Strap each one onto the robot sequentially, and hook up the wiring harness. Drive it around, and do an evaluation. Take the next box, and repeat.
For best results, use 3 identical boxes. After it's built, have someone randomly shuffle the boxes, then number them as you use them. That way, you won't know which is which until after your evaluation, when you open them up and compare the number to whats inside!
2016: Lake Superior WFFA
  #213   Spotlight this post!
Unread 18-12-2012, 16:32
CalTran's Avatar
Missouri S&T Senior
That'd be really interesting to do in off season. Now if only we had some extra Jags and new Victors.
  #214   Spotlight this post!
Unread 24-12-2012, 14:50
stewie2013 stewie2013 is offline
AKA: Stew
FRC #2013 (CyberGnomes)
stewie2013 is an unknown quantity at this point
they are only .1 of a pound lighter than a jag due to the heat sink on it
