Re: A Simple Elevator
http://www.team1551.org/Sheila2_400x600.jpg Our robot lift in Breakaway used the ecoslide carriage and lifted our whole robot no problem over and over again -- it didn't sway because it had little weight up top: it was just used to lift a hook, and then drew down to lift the whole robot. Last edited by pfreivald : 19-12-2012 at 09:22. |
Thank you everyone for their input. Our team used 80/20 sliders for our minibot deployment in 2011, and we swore them off after that. So I have tried to mock up a lift I think we could build image below:
![]() Specs:
Slightly skewing off the main conversation here, but I have another question pertaining to building a minimalist and robust elevator system:
I know the elevator is not taking a lot of horizontal load, but how do you ensure that there is enough support to prevent the elevator from leaning forward/backward? I see that Adam Heard of 973 has what looks like a minimal amount of support on Emporer Swerve, and I was wondering how our team should go about determining how much support is needed. |
Do you have any advice on how much support is necessary on this connection? |
#8
This must not be in the .step we posted? It's hard to quantity exactly what framing needs to be there, which is the same for most FRC frames. A decent, solid triangle is usually never a bad choice though. |
#9
1/16" steel cable is extremely light, really annoying to work with, and excellent at stabilizing elevators.
