Go to Post You are beautiful. - Joe Johnson [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 18-12-2012, 13:47
Dragonslayerend Dragonslayerend is offline
DuncanDynamics lead programmer
AKA: Tom Xiong
FRC #3970 (DuncanDynamics)
Dragonslayerend will become famous soon enoughDragonslayerend will become famous soon enough
BDC-COMM & CANJaguar function in C++
I have used the BDC-COMM to implement my PID loop. The mode was Speed, encoder PPR 360, and Quadrature Encoder as my Reference. The problem though is that I found out in Windriver, the PID loop while using CAN was jittery and unstable.
My code In Windriver:
SslTwo->ChangeControlMode(CANJaguar::kSpeed);
SslTwo->SetSpeedReference(CANJaguar::kSpeedRef_QuadEncode r);
SslTwo->ConfigEncoderCodesPerRev(360);
SslTwo->SetPID(-.003, -.013, 0);
SslTwo->EnableControl();
I also notice that the Integral part (__,ki,__) alone of the loop, when implemented in Windriver gave the erratic jittery behavior. While in the BDC-COMM it worked perfectly. Can I get some assistance on this, how come the PID loop erraticly jitters in Windriver and not in BDC-COMM?
Unread 19-12-2012, 17:23
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: BDC-COMM & CANJaguar function in C++
Are you sure you aren't disabling and enabling? Also are you sure your units are correct? I'm not sure that the units in the bdc-comm are the same as the API in WPILib. Maybe your constants are wrong.
Unread 05-01-2013, 20:23
AKA: Tom Xiong
I actually figured out that you can't do a slave and master using CAN, it was the problem that made everything jittery.
