Go to Post I know I exaggerated a bit, but NASA put a man on the moon with less processing than some FRC bots. Think about that for a minute. - JesseK [more]
Unread 20-12-2012, 04:32
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Re: [Help] Can ping, but DS says "No Robot Communication" only W7, ok from XP
Joe Ross: hadn't thought of that. Running AVG Free 2013; disabled it, no joy.
gnunes: only one ethernet port. double checked, wireless is disabled, wired enabled on correct port, ping and FTP work.
So still in same place: Communications lights on diagnostics panel shows "Robot" with a green light, I can ping and ftp the robot, but DS stills says "No Robot Communications". If I put a bad team number into the DS, then the "Robot"light goes red (as it should), and if I have the correct team number in the DS, but disconnect the cable, the "Robot" light goes red (as it should). I definitely have TCP/IP connectivity between the W7 box and the robot (green Robot light on diagnostics panel, ftp and ping work).
Who knows the difference between the green Robot light and the "Communications" light?"
I'm about to give up and start over with the 2013 DS in a little over 2 weeks; maybe the problem will go away then (or FIRST will be able to tell me how to get more troubleshooting information).....
Unread 20-12-2012, 06:14
Ooh, ooh, I know...
The Diagnostics page LEDs in that column mostly refer to ping results. The No Robot Communication message, and the light on the left permanent panel labeled Communications are much more of a summary and indicate whether the protocol is succeeding.
My guess is that the cRIO is not running the FRC Communications task and is not responding to control packets. Image the cRIO. You can verify this further if needed by using netconsole or the serial cable to view the console trace. You could also identify if that task is running or not. But since most folks don't have a null-modem serial cable laying around, I'd reimage and see if the issue is resolved. Be sure to click the format checkbox in the imaging tool.
Greg McKaskle
Unread 20-12-2012, 09:57
fovea1959's Avatar
AKA: Doug Wegscheid
cRIO is running the task; swapping my XP machine in makes everything work perfectly. It's something on the W7 box...
Unread 20-12-2012, 11:18
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Is there any chance you are also using both a wireless and wired network connection?
Do both have the same domains, or do they both start with 10.xxx.yyy.zzz and you have a subnet mask set at 255.0.0.0?
It might be confused about which network connection to use to connect to the cRIO.
If so, try disabling your wireless, and go wired only.
Strange, because if you can ping it, it should be fine.
How are the ping times? any dropped packets?
Maybe you can try a "tracert" and see if anything fishy is going on.
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 20-12-2012, 11:40
It still sounds like the FRC port traffic for the Driver Station is being blocked (or the port is locked up) by something on the Win7 machine (for your own security, of course).
You might scan from another machine to see what ports the Win7 machine has open using something like Angry IP Scanner
You've already eliminated the usual culprits - Windows firewall, anti-virus, extra NICs, intermediate router firewalls.
No other network related applications on the Win7 machine?
Perhaps booting Safe Mode with Network would eliminate the possibility of a third-party driver causing the conflict.
Unread 20-12-2012, 12:17
Kevin Fort Kevin Fort is offline
no team (Team NI)
Kevin Fort is an unknown quantity at this point
Does the cRIO show up in the imaging tool on the Win 7 machine?
If your wireless card is currently disabled try enabling it - if it is currently enabled try disabling it. We fixed most of the problems with this in the updates after week 1 of the season last year and it was mostly with the imaging tool but still worth a shot at this point.
Unread 20-12-2012, 13:29
One other thing I've seen affect this is having multiple IPs on a single NIC. Open the control panel and get to the IPv4 properties. That dialog contains an Advanced button. If you happen to have multiple IP addresses set, delete all but one.
You can also see this if you use ipv4 or perhaps netshell.
Greg McKaskle
Unread 20-12-2012, 16:15
AKA: Mr. Lim
Does your W7 machine support Gigabit Ethernet?
Try going to Device Manager and manually configure the speed of your Ethernet down to 100Mbit Full-Duplex.
I've had machines be able to ping, but not actually send reliable packets via Ethernet if auto speed/duplex negotiation is on, and I don't have cabling which can reliably support Gigabit speeds. It tries Gigabit speeds, it sortof works, but then stalls.
Unread 28-12-2012, 15:53
Secretspy97 Secretspy97 is offline
FRC #1126
Secretspy97 is an unknown quantity at this point
Your netmask should be 255.255.255.0 not 255.0.0.0.
WHAT TIME IS IT?
1126
Unread 28-12-2012, 19:30
fovea1959's Avatar
AKA: Doug Wegscheid
just trying to stay focussed on underlying problem: netmask is not the problem, else ping, ftp, etc, would not work.
frc documentation states clearly that 255.0.0.0 is correct (ref: http://www.usfirst.org/uploadedFiles...adio_Rev_A.pdf, http://www.usfirst.org/sites/default...20System_2.pdf)
in any case, either netmask 255.0.0.0 or 255.255.255.0 will work for 2 clients, 10.xx.yy.2 a nd 10.xx.yy.6.
Unread 28-12-2012, 19:56
FRC #1126
I believe that 255.0.0.0 is for configuring your radio not to communicate with your cRIO;
The 2012 control system says that you need to change it to 255.255.255.0 as stated by FIRST in http://www.usfirst.org/sites/default/files/uploadedFiles/Robotics_Programs/FRC/Game_and_Season__Info/2012_Assets/Getting%20Started%20with%20the%202012%20FRC%20Cont rol%20System_2.pdf(page 16, bullet 6).
You are currently just pinging the radio not the cRIO.
You can see if this is true by connecting directly to the cRIO and then try to ping it.
I know that it is possible for a windows 7 computer to work because I currently use a windows 7
computer to deploy code to our robot. I had the same problem and this fixed it.
WHAT TIME IS IT?
1126
Unread 28-12-2012, 20:23
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
You can see if this is true by connecting directly to the cRIO and then try to ping it..
OP can definitely ping and FTP to the cRIO.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 28-12-2012, 20:28
FRC #1126
Can you deploy code to the cRIO?
WHAT TIME IS IT?
1126
Unread 28-12-2012, 22:09
fovea1959's Avatar
AKA: Doug Wegscheid
I let the DS configure the wired NIC, it set a netmask of 255.0.0.0. Cannot be possibly pinging or FTPing the radio, since there is none (running crossover cable from W7 box to cRIO)
SecretSpy97: good question. I can deploy code to cRIO just fine from W7. Can even see the disabled elapsed seconds increase in Disabled.vi.
what would cause DS to not think cRIO was there when everything else can access it? It smells like firewall or such, but firewall is turned off, as is AV...
Unread 29-12-2012, 04:40
AKA: Mr. Lim
Are all three of:
LabVIEW Update
Utilities Update
Driver Station Update
Installed, in addition to the files from the USB key? Sounds like your DS might be missing some library files which support TCP/IP communications.
It makes sense if all firewall, AV and such is off, and the only application that can't connect to the cRIO is the DS. Does the cRIO imaging tool recognize it?
http://joule.ni.com/nidu/cds/view/p/id/2261
http://joule.ni.com/nidu/cds/view/p/id/2262
http://joule.ni.com/nidu/cds/view/p/id/2263
