Go to Post Innovating for the sake of innovating, reinventing the wheel is probably the second biggest pitfall you can fall into when designing an FRC robot, if the wheel is already a very optimized, good solution. - Chris is me [more]
Unread 20-12-2012, 21:23
μC/OS
Anybody ever use this?
ID:	13334  Click image for larger version
ID:	13335  Click image for larger version
Unread 20-12-2012, 21:41
flameout flameout is offline
AKA Ryan Van Why
FRC #0957 (SWARM)
flameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to allflameout is a name known to all
Re: μC/OS
I haven't used that specific RTOS, but I have tried out ChibiOS/RT once (note: I have not actually made an application with it, but I've deployed it to an ARM-based board).
Are you asking with a specific application in mind? If so, I have experience with Xenomai and RT-PREEMPT-patched Linux kernels (in addition to my research on ChibiOS) and may be able to offer suggestions (having looked into other realtime operating systems).
Unread 20-12-2012, 21:51
Re: μC/OS
Originally Posted by flameout View Post
Are you asking with a specific application in mind?.
I'm just wondering if anybody in CD-land has used μC/OS, and if so, was the experience positive.
Unread 20-12-2012, 21:58
AKA Ryan Van Why
FRC #0957 (SWARM)
Re: μC/OS
Thank you for clarifying.
Although I haven't had experience with µC/OS, I will add that the little experience that I've had with ChibiOS has been positive.
Also, my experience with Xenomai hasn't been perfect, but it's been pretty good (networking in Xenomai depends on RTNet, which has minimal maintenance.) So far, I've never had success with RT-PREEMPT, but it remains the most promising option for what I've been doing.
Unread 20-12-2012, 22:57
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: μC/OS
I used μC/OS II on a Jackrabbit processor for my Senior deign project in college (in 2004). Even though I am not a programmer, I was able to get a system going with 5 tasks on it, and the task manager worked pretty well. There are a ton of OSes to be used, and it largely depends on your application. That's one of the fun bits of engineering - figuring out what you can use, and having it be simple and effective.
Unread 22-12-2012, 22:54
Re: μC/OS
"Fundamentals of Real Time Operating Systems" webinar, if you're interested:
http://seminar2.techonline.com/~fund...os/player.html
Unread 28-12-2012, 21:47
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: μC/OS
I know Jean Labrosse personally. μC/OS is a nice RTOS if you have the right kind of application. They now have a company called Micrium that sells the updated version of μC/OS.
There are several evaluation platforms that are available really cheap like this one: http://www.st.com/internet/evalboard/product/247091.jsp . μC/OS works quite well with the Cortex M0/M3/M4 series processors as well as with the Renasas processors. Very reliable and dependable with great latency numbers.
Good luck,
Mike
Unread 28-12-2012, 22:58
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: μC/OS
I cannot say I've used that one, but one of the professors at my University, Mississippi State University, wrote their own embedded operating system for the PIC24 Microcontroller.
It's called ESOS, for Embedded Systems Operating Systems, which was designed to be used for our Embedded Systems class, but can be used outside of school, as the source code is available.
http://www.ece.msstate.edu/courses/e.../_e_s_o_s.html
It was primary developed by Dr. J.W. Bruce, but the source and ideas used for the source have been pulled from multiple sources. Ahem... ALL THE SOURCES!!!
Anyway, it's another consideration to take for a µC OS for non-RT development.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 29-12-2012, 00:23
virtuald's Avatar
virtuald virtuald is offline
RobotPy Guy
AKA: Dustin Spicuzza
Re: μC/OS
I used μC/OS-II back in college... maybe 2006-2007ish. I fixed a broken port of it to some freescale processor. It was interesting, pretty well written from my point of view at the time.
Unread 29-12-2012, 00:43
Re: μC/OS
The book is a good read, if you're interested in RTOS stuff.
