Go to Post EVERYTHING in life is politics. - Amanda Morrison [more]
Unread 19-12-2012, 17:20
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
[FTC]: NXT Lockups in LabVIEW
Hi
Over the last two days, I've had my NXT lock up twice during Teleop.
Fresh Batteries, New NXT, Correct Firmware, Correct template.
I have used some advanced Labview coding, but nothing that has been reported as not supported.
The weird thing is that when it happens, the NXT goes into that tick tick tick mode that occurs during a firmware update. The screen just freezes and you need to pull the batteries. Works fine on replacing the batteries.
Before I head down the long road of trying to get this to occur on demand, anyone seen anything similar with a well defined cause? No conjecture or speculation please.....
Phil.
Phil Malone
http://www.GEARSinc.org
Unread 20-12-2012, 19:29
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
when I did (and mentored) ftc and fll this happened alot it is a sign of the brick dying and has nothing to do with the code you might be able to send it back for repair/replacment
Unread 20-12-2012, 22:16
TRWSHSHLX TRWSHSHLX is offline
AKA: Henry Lei
TRWSHSHLX is an unknown quantity at this point
Re: [FTC]: NXT Lockups in LabVIEW
Last year when our robot's NXT locked up, we found out it was due to static electricity build up. Was the robot mechanically altered in anyway right before the lock ups start occurring? Also, is your robot grounded?
Unread 23-12-2012, 10:11
VashonRobotics's Avatar
VashonRobotics VashonRobotics is offline
AKA: Bruce
FTC #3861 (Vashon Pirates)
VashonRobotics is an unknown quantity at this point
Curious how you came to the conclusion that it was static build-up? What was causing it? What was being affected? (NXT, Samantha, etc) How did you end up solving it? Thanks!
Unread 23-12-2012, 13:45
AKA: Henry Lei
We put anti-slip mat or some sort of "absorbing" material around the NXT to lessen the vibrations that occurs during match play. And after that change, the NXT would lock up just randomly. It was also partially due to the high traction tires we have on the robot.
Nothing else seemed to be affected. We found a better way of shock proving the NXT and added a grounding wire and NXT didn't freeze up anymore.
Unread 08-01-2013, 16:27
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Originally Posted by PhilBot View Post
Hi
Phil.
Phil,
Any updates on this? While helping 4314 I encountered the same issue, However this happens very consistently using tether or samantha. I do hear the clicking noise a couple of seconds after enabling the robot.
The code is very basic. The only addition beside regular VI's is the hitechnic prototype board VI to read an analog.
Spent about 2 hours troubleshooting this with no luck.
While I have done some more advanced stuff in labview and I am a fan, The FTC implementation of labview in addition to the NXT has just been bad. And especially horrible this season. Just my opinion.
-Borna Emami
Team 0x27
Unread 09-01-2013, 08:09
PhilBot's Avatar
AKA: Phil Malone
Originally Posted by BornaE View Post
Phil,
Hi
After we had this happen a few times, one of the kids thought he remembered that it had hapenned on their robot a few years back and it was "caused" but metal shavings falling into the NXT wire sockets on the motor/servo controllers.... that is... an electrical problem on the communications bus.
While I didn't specifically recall this (or believe it) , I thought it was probably a good idea to ensure that all the connectors were free of debris, so we did a serious vacuum inside all the sockets, and then we put electrical tape over all the open connectors sockets.
Oddly enough, we haven't seen the lockup since them (knock wood).
The fact that you are using the prototype board might indicate that you possibly have a bad connection that is also effecting the communications on the NXT data bus.
Do you get the same problem if you unplug the proto board?
Phil.
Phil Malone
Unread 11-01-2013, 23:26
iPenguin's Avatar
iPenguin iPenguin is offline
AKA: Adam Lowe
FTC #5875 (GENIUS)
iPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant future
As an FTA, I can confirm that both of these cases can be likely causes of the NXT locking up. I don't believe it has anything to do with specifically using LabVIEW or RobotC - I've seen equal cases of both. What can happen is that Samantha will for some reason send a "bad message" to the NXT, and the NXT doesn't know what to do with it, and therefore locks up. I've spoken with other FTA's and, unfortunately, we really don't know why this happens, or what to do to prevent it.
Phil's suggestions for vacuuming and covering unused ports are good ideas. That USB cable between NXT and Samantha is very critical. Make sure it is secured tightly. It's also been suggested to get a couple small USB extension cords that permanently stay attached to the NXT and Samantha. This also helps for your Software Inspectors who need easy access to Samantha's USB port.
Hope this helps!
2013 Season-Long Fantasy FIRST Elgin Clock Award Winner - Peach Alliance
Since 2008
2012-Present: FTC #5875, GENIUS
2008-2012: FRC & FTC #1002, The CircuitRunners
"Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple."
~Gene Wilder as Willy Wonka
Unread 16-01-2013, 15:34
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Originally Posted by iPenguin View Post
Hope this helps!
It does help and I second your conclusions. I've noticed the lockups don't have a code preference. But when some of those hits between robots occur, you get robot lockups later in the match.
As a request from an FTA, if a lockup occurs, it helps to diagnose the robot if the NXT is visible and to turn it off if the power switch is easily reachable. It hurts when I have let a robot death spiral cause the power switch is under the robot lifter or NXT.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 21-10-2014, 08:54
Hodgepodgerama Hodgepodgerama is offline
FTC #8510
Hodgepodgerama is an unknown quantity at this point
All, there is now an excellent article on the FTC Team Resources page on NXT lock ups. It covers the issue and how to resolve it. We purchased the item mentioned in the article and have had no lock ups.
