Go to Post I, being a Trekky myself, will really enjoy a Star Trek themed game if it turns out to be that. I will not enjoy programming the alcubierre warp drive. :D - AveryLevin. [more]
Unread 20-12-2012, 22:42
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
pic: Another Team 691 Swerve Module
Unread 20-12-2012, 22:43
FRC #1836 (MilkenKnights)
Re: pic: Another Team 691 Swerve Module
How thick is that tread?
Unread 21-12-2012, 02:35
Garret's Avatar
AKA: Garret Smalley
The tread is 1.5" thick on a custom wheel 3" wheel. The wheel can be swapped for a dead-axle 3" colson if I change the shaft from 5/8" to 1/2".
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 21-12-2012, 14:40
Chris is me's Avatar
AKA: Pinecone
Any reason you can't run 3/8ths and use the COTS Colson hub? I'd be wary of using the super thin roller bearings in a drivetrain application.
Unread 23-12-2012, 22:41
AdamHeard's Avatar
Lead Mentor
Why?
Is the COTS hub you're referring to the stock delrin bushings, or the WCP hub?
Unread 24-12-2012, 00:50
Garret's Avatar
AKA: Garret Smalley
Sorry for not responding earlier, there isn't any reason that prevents me from doing that, it would simply require the hole to be drilled out and the shaft replaced with a 3/8" bolt.
I hadn't done something like that initially because I was testing out the feasibility (from a design point of view) of having the module hold itself together as if it were one single piece. In this case the axle was actually a tube that fit into counter-bores on the two side plates, the intent was to make the shaft a structural member. This was done with the rest of the module by having the parts fit into slots or holes that would hold their positions instead of fasteners.
For this module only the 2 larger bolts going through the top are necessary to hold the module together and the other large bolt on the bottom just helps "strengthen" the shaft if the game required it (bumps, falling, etc...).
7 Years of FRC
Unread 24-12-2012, 13:53
AKA: Pinecone
You can still do a 3/8 tube axle and just tap the ends. I like the idea of using the bottom axle to make the module more rigid. You can't be too rigid with this kind of design!
Unread 25-12-2012, 00:00
Garret's Avatar
AKA: Garret Smalley
I hadn't thought of doing that, that would actually be quite elegant if it is strong enough.
7 Years of FRC
