Go to Post If it is good enough for Paul and JVN it's good enough for me. - Vikesrock [more]
Unread 21-12-2012, 16:05
jalmos jalmos is offline
FRC #4166
jalmos is an unknown quantity at this point
Setting our IP address back after competition
Hello, this is something our team is stuck on although it seems like it should be simple even for a rookie team like us.
After last years competition we are having trouble changing the IP address of the router back to the original address. It is still set on the IP address of the competition and we can no longer drive our robot wirelessly with setting it back.
Any suggestions for a rookie team?
Thanks for your time
Jalmos
Unread 21-12-2012, 16:10
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Re: Setting our IP address back after competition
The basic idea is that you convert it back to running on 2.4ghz mode and disable the security.
I can't find the 2012 instructions but team 358 has the 2011 and they are basically the same.
http://team358.org/files/programming...adio_Rev_A.pdf
Unread 21-12-2012, 16:11
BigJ BigJ is online now
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
My suggestion would be to reset the router (just like you do at competition before imaging) with a paper clip, then follow the normal control system setup instructions to configure it.
Edit: or turn the security off as the previous poster said.
FRC #4166
Thanks we will give that a try. Much appreciated
Jalmos
Unread 21-12-2012, 16:31
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
Make sure the switch on the back is set to AP mode, not bridge mode. That's the one thing nobody has touched on yet.
I also recommend just resetting it (via paperclip) as BigJ said and then setting it up normally.
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 21-12-2012, 17:16
Saberbot's Avatar
Saberbot Saberbot is offline
Ask me about Glentite™
AKA: David Ingraham
FRC #4146 (Saguaro Sabercat Robotics)
Saberbot is just really niceSaberbot is just really niceSaberbot is just really niceSaberbot is just really nice
I've done it 5 times and it's still a pain...
The directions on page 29 of this document are very helpful.
Unread 22-12-2012, 19:27
runneals's Avatar
runneals runneals is offline
FTC Mentor - The Robot Corps 7491
FRC #3928 (Team Neutrino)
runneals has a spectacular aura aboutrunneals has a spectacular aura about
Just do a hard reset (using the paperclip to hold the reset button in until the router's lights blink like 1 or 2 times)... Then the access point should default to "dlink" or something like that. The IP to connect to it is like 192.168.1.1. Hope this helps.
David Runneals
FRC 3928 Team Neutrino 4-H: Mentor (2015 Off-Season - ?)
FTC North Super Regional Championship: Game Announcer (2015)
FTC 7491 The Robot Corps 4-H: Mentor (2013 - ?)
FRC 2167 Mentor (2014)
FRC 3928 Team Neutrino 4-H: Member, Co-Captain, & Media Coordinator (2013)
Unread 22-12-2012, 19:30
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
I'm pretty sure it defaults to 192.168.0.50, but it should say on the bottom of the box. And again, a reset isn't going to help unless the switch is physically in AP mode.
