Go to Post Curse you and your logic! - Koko Ed [more]
Unread 17-01-2003, 01:09
Jon Lawton Jon Lawton is offline
Bitter FIRST Cynic
Jon Lawton is an unknown quantity at this point
Send a message via ICQ to Jon Lawton Send a message via AIM to Jon Lawton
Matching Drill and Fisher Price Motors
Okay, so I have been racking my brains for quite some time trying to figure out how to match the drill and fisher price motors. I have finally come to a solution, and am seeking peer review.
First, the motor specs:
Units: RPM, Amps, N-m, Amps
Drill Motor: 19670 FreeSpeed, 4.5 FreeCurrent, .87 StallTorque, 127 StallCurrent
Fisher Price: 15000 FreeSpeed, 1.1 FreeCurrent, .38 StallTorque, 57 StallCurrent
Then, I decide where I want to run my motors on the Torque-Speed Curve:
Drill Motor (Maximum Power occurs at > 40A):
Speed at 40A = (40-127)(19270)/(4.5-127)=13969.7 RPM
Torque at 40A = -0.87/19670 * 13969.7 + 0.87 = .252123 N-m
Fisher Price Motor (Maximum Power at 29.05A):
Speed: 15000/2 = 7500 RPM
Torque: 0.38/2 = 0.19 N-m
Then I calculated the total torque I'd need, assuming 130lb robot, 1.0 Coefficient of Friction (yes, I measured thereabouts), and 6in diameter wheels:
130lb *3in = 390In-lbs
578.5N * 0.0762 m = 44.0817N-m
Then I made up a table of successive 2:1 reductions and listed the effective torque and speed at each. I noticed that after 5 stages, the Fisher Price motor would spin at 234.375 RPM when loaded at 6.08 N-m, and after 6 stages the Drill motor would spin at 218.277 RPM when loaded at 16.128. Those speeds almost match exactly, and the torque adds up to right about 44N-m. Bingo!
So I derived:
Speed=7500/RatioFP
Speed=13969.7/RatioDrill
7500/RatioFP=13969.7/RatioDrill
Using simple algebra, I got further:
RatioDrill = 1.86263 * RatioFP
RatioFP = .536876 * RatioDrill
Okay, so since I am using two Drill motors and two Fisher Price motors, I know the total torque of these four motors must add up to 44N-m.
2*(.19*RatioFP)+2*(.232*RatioDrill)=44 N-m
Now the problem becomes simple substitution!
2*(.19*(.536876*RatioDrill))+2*(.252*RatioDrill)=4 4 N-m
RatioDrill = 62.1458:1
And, with the same method:
RatioFP = 33.3646:1
Please note, that this assumes 100% efficiency, which WILL NOT be the case. To yield better ratios, use:
2*(.19*RatioFP*.9^nStages)+2*(.232*RatioDrill*.9^n Stages)=44 N-m
Where nStages is the number of stages of gearing to achieve each overall ratio. 90% per stage is a conservative estimate to account for all of the various losses.
My math also says my wheel will be spinning at 224.789 RPM under this load condition (exerting 130 pounds of force). My wheel has an 18.84 inch circumference, so that comes to 5.88 feet per second.
So once I account for losses, I'd wager I'm somewhere between 4.5 and 5 feet per second pushing with 130 pounds of force.
What a beast! What does everybody think?
Unread 17-01-2003, 07:15
Gui Cavalcanti's Avatar
Gui Cavalcanti Gui Cavalcanti is offline
Robogeek
Gui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to allGui Cavalcanti is a name known to all
Send a message via AIM to Gui Cavalcanti
Hey, cool!
Sounds cool!
First of all, I'm curious as to why you are using the Fisher-Price and drills instead of the CIM and drill.
The way our team has done it is we have taken the slowest motor (in this case, the drill with high speed transmission @ 1500 RPM) and matched the faster motor (CIM @ 5500 RPM) to it.
That system is really cool though, and it looks like it would work. What would the "near free speed" be when the robot is not pushing? I'm sure your team would be interested in that.
Gui Cavalcanti
All-Purpose College Mentor with a Mechanical Specialty
Franklin W. Olin College of Engineering, Class of 2008
Unread 17-01-2003, 08:31
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: Matching Drill and Fisher Price Motors
This is probably the most effective way to match the ratios, by using these two speeds instead of free speed matching... good job!
I think that you are underestimating the speed and power of your system. There are two things that you can change to give yourself a dramatic increase in your calculated speed and power.
1. Don't settle for a series of 5 or 6 stages of 2:1 reductions. Go for a couple of 4:1 reductions and reduce the # of stages.
2. A 90% efficiency loss at each stage is VERY conservative. As long as you use ball bearings to hold the shafts and get +/- 0.002 or so with the accurracy of your bearing hole locations, you can get up to 97% efficency. Take your time in doing this, and your 'bot will go faster and have more power.
Figuring efficiency loss with 0.9x6 is much less than 0.97x3.
At least, that is the way I see it. Unfortunately, our team doesn't do enough post-season evaluation of output power to see if these thoughts are accurrate. I'm very interested to see others opinions on this also.
Jon... excellent job. I especially like that your system will probably be more fast and powerful than you are estimating... which will make your design skills look even better.
Andy B.
Unread 17-01-2003, 10:45
Lauren Hafford Lauren Hafford is offline
#0159 (Alpine Robotics)
Lauren Hafford is an unknown quantity at this point
Send a message via AIM to Lauren Hafford
Drill output shaft
My team (me especially) had a lot of trouble finding a stinkin' metal spur gear to attach to the drill motor (because we aren't going to use the gearbox that came with it for space reasons). It is Mod .7 and the only site I found which had that availible (in stainless steel - better than nylon found on globalspec!) is:
www.pic-design.com
it's such an obscure pitch, and on top of that we wanted a gear with 64 teeth!
So anyway, I hope that this helps out another team.
Lauren
Unread 17-01-2003, 11:20
President, VEX Robotics, Inc.
Great Job!
Jon,
Your system for calculating speed matching is right on. If you want some more information (and reinforcement that your right on), look in the white papers section unde "Novi Kickoff". I put my preso from this year's kickoff in there. It specifically adresses the problem you worked through.
I agree with Andy that 90% is way too conservative. We use 97% and it matches our output tests pretty good. Also, try to get 3 or 4:1 reductions if you have the real estate; because, like Andy said, it will pay off.
I compliment you on your analysis. It is very well thought out.
One word of caution, when you are not operating at 30 (40) amps, the slower motor will act as a generator and not contribute much to the output torque. (When running at top speed) Do the mat and you will see what I mean.
-Paul
Unread 17-01-2003, 11:30
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Excellent Job Jon!
I here by announce and appoint you the teacher for 2004 WRRF motor workshop. Start preparing NOW!
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 17-01-2003, 17:04
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Originally posted by Ken L
Excellent Job Jon!
Or he can just wait until the night before, and pull an all-nighter, like you did...
Jon: I've already told you this, but $@#$@#$@#$@# if that isn't some of the coolest stuff I have ever seen.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Need Fisher Price Motors kevinw Motors 1 13-02-2003 18:44
Wiring Fisher Price Motors Ralph Lambert Motors 2 10-02-2003 14:40
Fisher Price Motors for Drill Motors archiver 2001 0 24-06-2002 00:22
