Go to Post This should go without saying, but for some reason it always needs saying. - GaryVoshol [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 7 votes, 4.57 average. Display Modes
  #226   Spotlight this post!
Unread 21-12-2012, 20:09
CrazyHorse's Avatar
CrazyHorse CrazyHorse is offline
AKA: Lance Welch
FRC #3259 (Thoroughbots)
Team Role: Driver
CrazyHorse is an unknown quantity at this point
Re: 2013 ACTUAL game hint!!!
Originally Posted by coalhot View Post
Sorry if I misread something, but all that Frank said is that there was no mistake made on the page. We assumed that the KOP frame dimensions may have been a mistake, since it was different from last year, and 8 isn't too far from 0 on the keyboard. That being said, it seems as if it's a rule change, unless the longer parts of the frame are hidden somewhere else. You can never rule out the sneaky GDC.
I think he was replying to my message about what Frank said. Haha
Team 3259 The Thoroughbots
2012 SMOKY MOUNTAINS REGIONAL CHAMPIONS: Thanks 772 and 234
2012 SMOKY MOUNTAINS REGIONAL JUDGES AWARD WINNERS: Thanks William "The Funk Master" Funke
2012 C.A.G.E. MATCH CHAMPIONS:Thanks 3940, 234, and 1018
  #227   Spotlight this post!
Unread 21-12-2012, 20:10
JJackson's Avatar
JJackson JJackson is offline
FRC #0781 (Kinetic Knights)
Team Role: Driver
JJackson is an unknown quantity at this point
Keeping with the idea of three, could we see three differently shaped game pieces? Maybe tetras, track balls and rubber-maid containers.
  #228   Spotlight this post!
Unread 21-12-2012, 20:11
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Replying to my own post...I forgot to account for the 8" of wheels in those designs, so they are indeed 28"x38"
But, I suppose that begs the question that others have alluded to: What about the designs that are already out there for 28"x38". Sure, teams could be required to redesign, but there is an economy to FRC. What about the suppliers that have based designs on (and hence produced parts for) that footprint? Are they all just out of luck if the dimensions are changing?
Or, prehaps the dimensions aren't changing, but the kit bot is different. A 30" long dimension plus 8" of wheels is closer to the 38" we are used to. It just means that the kit bot frame doesn't "wrap" the wheels as it has in the past.
...As always with the hints, we are all merely speculating.
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
  #229   Spotlight this post!
Unread 21-12-2012, 20:16
CalTran's Avatar
CalTran CalTran is online now
MST Rolla Senior
...what?
Academic Student (Forever)
  #230   Spotlight this post!
Unread 21-12-2012, 20:21
FRC #6357
I was merely suggesting that others may be reading too much into the dimension of the "kit bot" (AndyMark Drive Base Kit) that comes with the kit of parts. Just because the longest dimension part in that chassis is 30" does not mean that the maximum length of the robot is 30" or anything less than 38". Using that same c-channel frame, one can construct a robot with a 38" outer dimension using frame parts that are 30" long.
FLL Mentor 2006
FRC 619 Mentor 2002
  #231   Spotlight this post!
Unread 21-12-2012, 20:24
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
But, I suppose that begs the question that others have alluded to: What about the designs that are already out there for 28"x38". Sure, teams could be required to redesign, but there is an economy to FRC. What about the suppliers that have based designs on (and hence produced parts for) that footprint? Are they all just out of luck if the dimension are changing?
This is all speculation. The only solid hints are the KOP sizings.
This is interesting though, if you think about it. None of the boxes seem to include the game piece, and from my experience, the veteran KOP is about half to 3/4 full. which means the game piece is either small, or inflatable (or not included with the kit).
That being said, we've had balls in the game for 4 out of the last 5 years. I have a feeling that this game piece is not going to be a traditional round ball. It may be some other ball though. Also, with all the "3" hinting, something is going to be radically different. It's about time too...
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
  #232   Spotlight this post!
Unread 21-12-2012, 20:28
coalhot's Avatar
AKA: Phil
While that may be true, there are downsides of using multiple pieces of c-channel to span a distance. Two are rigidity and mounting space. If i'm not mistaken, AndyMark used to ship 4 pieces of 38" C-channel, and let teams cut it down. Why wouldn't they do the same if there wasn't some sort of change?
EDIT: AndyMark sells C-Channel in 35" lengths. That makes me think that they had to fabricate a part especially for this KOP, a special part.
  #233   Spotlight this post!
Unread 21-12-2012, 20:29
Ekcrbe's Avatar
Ekcrbe Ekcrbe is offline
When can I watch Einstein again?
AKA: Erik Boyle
FRC #4640 (Metallic Panthers)
Ekcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond reputeEkcrbe has a reputation beyond repute
Two problems I see with the protruding-wheel theory are:
  1. I don't think the kitbot will have 8" wheels, meaning the max reasonable long dimension is ~35" (30" + ~2.5" each way from a 6" wheel)
  2. Losing or moving the front and rear bars on the kitbot doesn't seem like an intelligent move to make, given that the kitbot is intended to be a plain base to work off of, and not specialized to a specific design.
Four years of FRC 68 Truck Town Thunder
2012 Championship Newton Division Finalists—Thanks 330 and 639 for the Full Court Press!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166! | 2014 Waterford District Chairman's Award Winners! | 2014 Michigan FRC State Championship Chairman's Award Winners—Congratulations 33 and 503!
2015 Center Line District Chairman's Award Winners! | 2015 Lansing District Winners—Thanks 314 and 1684! | 2015 FIRST in Michigan District Championship Chairman's Award Winners—Congratulations 503 and 2137!
  #234   Spotlight this post!
Unread 21-12-2012, 20:32
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Another question about the KoP... We've heard a lot about the Kinect being in the game this year... I do not see a mention of it being in the rookie KoP though. Can anyone confirm/deny?
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
  #235   Spotlight this post!
Unread 21-12-2012, 20:36
FRC #6357
Hey, I may be wrong here. I agree that there are complications with protruding wheels. But, AndyMark does in fact make a general chassis (albeit pricier and more complicated than the "kit bot") using their NanoTube products that have protruding wheels. And those can be built off of to make a specialized chassis.
To me, it just seemed like there was no dissent to the idea that the allowed dimensions of the robot were changing. I wanted to present an argument that given all of the evidence we have, the assumptions being made here may not in fact bear out. ...Or they may bear out and we may be playing with smaller robots. We'll see on January 5.
FLL Mentor 2006
FRC 619 Mentor 2002
  #236   Spotlight this post!
Unread 21-12-2012, 20:40
coalhot's Avatar
AKA: Phil
I think AndyMark breaking from the traditional KOP Kitbot is enough change to warrant us talking of it as a hit. I may be completely mistaken though...
  #237   Spotlight this post!
Unread 21-12-2012, 20:43
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Originally Posted by CalTran View Post
...what?
Example ('scuse the paint):
I wouldn't trust that on my robot, bent wheels/axles due to impact don't seem like fun.
  #238   Spotlight this post!
Unread 21-12-2012, 20:45
coalhot's Avatar
AKA: Phil
Quick question, how does the bumper cover the extended wheel, and how do you prevent someone from ramming whatever bumper you have over those wheels into the wheels? seems like more of an issue than anything...
Edit: did't see the last line. But still, the question stands.
Last edited by coalhot : 21-12-2012 at 20:46. Reason: I can be stupid sometimes...
  #239   Spotlight this post!
Unread 21-12-2012, 20:46
CalTran's Avatar
MST Rolla Senior
That's what I thought. I don't think the KoP bot is going to that. The idea of the KitBot is something that rookies can easily compete with and I'd hate to imagine what would happen to that design the minute it gets t-boned.
Back to the game hint:
Any other revelations about what the string of numbers means?
  #240   Spotlight this post!
Unread 21-12-2012, 20:48
Kevin Selavko's Avatar
Kevin Selavko Kevin Selavko is offline
AKA: Voltonless
FRC #3260 (SHARP)
Team Role: Electrical
Kevin Selavko is on a distinguished road
Perhaps we will all get a new one in case any were broken/lost.
Team SHARP
Pittsburgh Regional Champions 2014
Vex Pittsburgh Excellence Award 2014
Vex Pittsburgh Champions 2014
Vex Maryland Champions 2014
Pittsburgh Regional Finalists 2013
Buckeye Regional Finalists 2013
