Go to Post guarantees don't mean anything when you're dealing with FRC good sir ;) - Zuelu562 [more]
Unread 21-12-2012, 23:55
ttldomination's Avatar
Sunny
Re: pic: 1156 3D Printed Wheel
Are there any other teams that can speak to using ABS plastic to print off wheels in respect to their durability?
Thanks,
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 22-12-2012, 00:00
FRC #1836 (MilkenKnights)
Thanks,
- Sunny G.
207 used ABS printed wheels in 2012 and 2011. In 2012 at championships they drove off the bridge, and their wheels did not break.
Unread 23-12-2012, 17:44
Botwoon's Avatar
Botwoon Botwoon is offline
A.K.A. Matthew Ruane
FRC #0207 (Metalcrafters)
Botwoon will become famous soon enough
We actually made a few sets for 2010 that didn't see much use. Those were reinforced with aluminum rings as they had a much greater diameter (8" and I think 10") than the ones we used this year and last year (4" and 5", respectively). We tap 10-24 threads directly into the wheels.
But anyway, here's a picture of the moment in question.
Unread 23-12-2012, 18:41
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Originally Posted by Brandon Holley View Post
Ding ding ding.
Dimension needs to take plastic filament and load it into each cartridge and assembly the other components (PCBA, rubber drive wheel) into it as we'll.
They're also probably making their margin on top of the cost of doing that.
-Brando
I can confirm that the cartridge is, in fact, one of the main reasons that Dimension's Material is usually more expensive than other printing options.
I ran an SST1200 for a little over 3 years before we switched to a Fortus 400mc this past fall at work. In our pricing negotiations, we tried to see if there was any way that the material costs could be driven down, and we were told that it couldn't, although ABS for the 400 is actually about 16% cheaper than it was for the Dimension. I was told that this was because that even though the 400's Canister is 'more expensive' to make, it holds more material (92 Cubic Inches), effectively lessening the effect of the Canister's increased cost... And for those of you complaining about Material Costs, we've got something that is ~$7.50 per cubic inch of model and support... eek.
It's really great to see teams making some important end use parts using 3D printing. With the right machine and a little know how, a lot of lower load parts can be swapped out to printed equivalents and still work really well.
