Go to Post Travel is a LOT less expensive when you pack the grown ups in the crate. - Rich Kressly [more]
Unread 21-12-2012, 19:03
ferrari77 ferrari77 is offline
FRC #2583
ferrari77 is on a distinguished road
Ideal robot speed
Assuming the the field is divided into two like Rebound Rumble what would be an ideal speed for a robot?
Right now we are looking at 6.1 ft/s according to JVN's design calculator but this could be 8.13 ft/s if a 32 instead of 24 tooth pulley is used on the gearbox
We are only going to have one speed but could potentially have a software limited slow speed for precise movements and aligning.
Unread 21-12-2012, 19:11
FRC #1836 (MilkenKnights)
Re: Ideal robot speed
We need more information. It's all based on the game. Different objectives and motor allotments allow/require different speeds(acceleration vs top speed). That said, 6.1 fps seems awfully slow. I'm pretty sure most teams that do 1 speed gear for something like 10 FPS.
Unread 21-12-2012, 19:31
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
To determine the best gear ratio (if you are using a single gearing), determine how far the average "drive" is going to be.
For instance - the average 'drive' in 2010 was much, much shorter than 2011.
Determine a guesstimate of distance for that year. Create a graph of distance over time, and play with your gear ratio to determine the highest ratio you can use that still gets you where you want to go in a reasonable time.
What you will very quickly discover that between 8-15 feet (perhaps the average drive of most games), you can use a very wide range of gear ratios for a very minimal change in time to reach your final point.
There really is an FRC 'sweet' spot around 10-12 FPS that works well in nearly every game.
Two speed shifters are a slightly different matter, and that is why teams that use them can go as fast as 14-18 FPS.
Unread 21-12-2012, 19:35
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Important Questions to frame this problem:
What CoF wheels are you using?
Is 100% of your weight on those wheels?
How many motors in your drivetrain?
Do you want your robot to be able to handle extended (more than 2-3 second) pushing encounters with walls or other robots?
Unread 21-12-2012, 20:03
ttldomination's Avatar
ttldomination ttldomination is online now
Sunny
Those who have posted in this thread are correct in that the answer truly depends, but let me attempt to give you a more definitive answer from experience.
For the past three years, we have used a standard toughbox reduction and then chained to the wheel.
In 2011, we used a nearly 1:1 chain to the wheel because of our 4" wheels. This gave us roughly 8 FPS. Here, the robot was strong and fast. The top speed was at a level that the drivers could handle with ease, and to be fair, no one was worried about our speed as our drivers headed out to pick up tubes.
In 2012, we used a 15:22 chain to the wheel because of our 8" wheels.This give us roughly 9 GPS. Here, the robot was also fast and strong, but I cannot recall a time when our robot ever reached top speed.
I'd be lying if I said that we planned for those speeds, but they worked out really well. This year also, if the game is flat-ish, I think we'll aim for 9.5. If the game requires getting rough with the field, then we'll push the lower limits of 8, maybe 7.5
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 21-12-2012, 20:06
Chris is me's Avatar
AKA: Pinecone
Assuming a high traction wheel, a little short of the weight limit, a 6wd style base, and a desire for a single speed that can primarily play offense while occasionally pushing, we've used 9-10 FPS for divided games (Breakaway and Rebound Rumble) and 11-12 FPS for full field games. You can't handle an extended pushing match directly this way, and you aren't quite as fast as you could be, but you're plenty fast for a modestly experienced driver to handle.
Unread 22-12-2012, 15:57
Levansic's Avatar
Levansic Levansic is offline
AKA: Len Evansic
FRC #0585 (Cyber Penguins)
Levansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud ofLevansic has much to be proud of
What good is top speed, if the robot never achieves it?
I pose the question, because speed, traction, and acceleration are a balancing act, and too many people here throw around their theoretical peaks as facts. Thank you for being honest about your robot's actual performance.
Almost a decade ago, I was working on a collegiate team, making robot soccer players (kaliken from 294, also). These robots were small, but pretty fast. We had geared them with a 9:1 ratio, but never came close to hitting top speed on our field. We changed to a taller ratio (14:1), which should have dropped our top speed by about 35%. Instead, our acceleration greatly improved, as did our achieved top speed. Even better, our motors drew less current and ran cooler, which helped battery life in our 30 minute all-out matches. The drivetrain has to contend with the inertia of the robot, and this is missing from most back of envelope drive calcs.
Back in FIRST, I see too many rookie teams at competition, with low gear ratios, hoping for high speeds. Their robots barely move, and scrubbing in turns causes complete standstill. Many on this forum calculate theoretical speeds, and live with what they have committed themselves to. The best course, if possible, is to do your calculations, but make sure to test several ratios above and below. Pick the one that best suits your robot, and your team's strategy with the game.
Unread 22-12-2012, 16:23
Tom Line's Avatar
This is exactly why you need to play with your ratios and look at the time it takes to cover distances.
A top speed of 20 feet per second sounds great, but it will obviously take far too long to get to that speed 90% of the time. You'll be draining your battery because your motors will be working too hard. That's why shifting is needed to realistically attain that speed.
Of course, JVN made a very good point. We need far more information to quantify this for the OP.
Unread 22-12-2012, 16:32
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
This is a very good point. Look at the time it takes to get from point A to point B. That time will be a combination of acceleration rate and peak speed and you want to find the combination that gets you the lowest time.
You can calculate an acceleration rate and top speed, and draw a curve for the options. Or, you can build a chassis and do some testing with combinations and accurate measures to get "real" data to make your decision. Both are good approaches.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 22-12-2012, 16:53
Andrew Lawrence
Posts: n/a
And if you want a decently high speed (maybe 14 fps?), but still want pushing power, this: http://www.andymark.com/ToughBox-p/am-2388.htm should be something to look at.
And for that price, who wouldn't want one?
Unread 22-12-2012, 18:26
Sunny
Hmm, I don't know the answer to that first question because honestly we don't plan to not hit our top speed. If you truly want to optimize your DT, then I'd suggest following Tom's methods.
Your second point also rings true in many regards, which is why my team has always favored to opt for a slower speed just so we can turn/push our way around the field. However, I think staying between the 7-10 range is probably a good sweet spot to make sure that your robot will at least be able to move.
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 22-12-2012, 21:39
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
I don't even know what our top speed is. Its generally not that important because we don't spend much time there. For the past two years we have run CIMple boxes with a 10 tooth output sprocket, and 32 tooth sprockets on 6" wheels. I think top speed is around 7 fps (at 4000 rpm CIM speed). I have never found myself wishing we could go faster. Most games are about getting in position to pick up or deposit the game piece. That is all about control. Getting from point A to point B usually involves getting around object C, pushing robot D, or going over obstacle E. None of those involve top speed, but all require torque/acceleration.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
Unread 22-12-2012, 22:03
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
top speed isn't as important as "quickness of a robot" because in most cases a FIRST robot spends most of its time moving in short bursts, not long straights where it has distance to get up to speed. from observation a robot that is "quick" can get up to speed in about 1 to 1.5 "robot lengths"
My Instructables
Unread 23-12-2012, 00:39
Levansic's Avatar
AKA: Len Evansic
The original question was about ideal speeds. Perhaps I wasn't as explicit in my last post as I should have been. The ideal speed depends on the strategy your team decides to pursue. A robot design that attempts to have superlative perormance in all aspects, will rarely perform in any.
Is your strategy to get to the other side of the field ASAP? If so, ideal speed is as fast as your robot can muster. As Tom mentioned, just gearing for a high speed may not be enough to hit a high speed. The fastest may be a moderate speed robot that hits its highest speed by midfield.
If your strategy involves fine control, maneuverability, or pushing, then lower speeds will be of much more benefit. For most past games, torque and it's matching acceleration has been much more important than speed.
Shifting gearboxes can provide for both speed and acceleration, with the trade of complexity and weight. Shifting is not a realistic option if your robot uses omnidirectional drive or mechanum wheels.
As an aside, the soccer robots I mentioned earlier used omnidirectional wheels, and could pull 1G acceleration in any direction. The same theory applies to omni and mechanum, as regular wheels or tank treads.
In short, we need to see the game, and your team will have to decide which strategy they will focus on. Ideal speed is strategy-specific and robot-specific.
Once the game is released, and your strategy is decided, then it is time to build and test a simple base with your chosen drive type. It doesn't have to be your final design, just representative enough. Load it up to 120 lbs, and break out the stop watch. Run trials with each gear ratio you can, and see what gives your robot the optimal performance for your chosen strategy.
One last point; if your robot is going to be tall, with a high center of gravity, then make sure you approximate this on your test base. Too much acceleration with a high CG can be very bad. In this case, you may be better with a hi-speed gearing and lethargic acceleration.
Unread 23-12-2012, 00:56
Tom Line's Avatar
I'll throw some numbers out to quantify this quickly. Hopefully, this is a real eye-opener for teams who have never done the math. This assumes a 4 cim drivetrain. This assumes you are accelerating from a stop. Someone check my math.... this was thrown together quickly.
Ratio: 4.2:1
Top Speed: 18.02 fps
Time to cover 10 feet: 1.18
Ratio: 7.1: 1
Top Speed: 10.60
Time to cover 10 feet: 1.20
Ratio: 10:1
Top Speed: 7.51 fps
Time to cover 10 feet: 1.44
Ratio: 12.5:1
Top Speed: 6 fps
Time to cover 10 feet: 1.63
The difference between an 18 fps drivetrain (no shifting) and a 6 fps drivetrain over 10 feet is about .4 seconds. Shifting introduces another variable, but you can see where I'm going with this. Erring for a higher gear ratio will rarely leave you disappointed. Due to acceleration timing, a top speed of 10.6 fps is only .02 seconds slower than an 18 fps over 10 feet without shifting.
In fact, over 10 feet a robot geared for 18 fps will only hit about 15 fps.
This segways into a very interesting argument about when you should design for shifters.
