Go to Post Or use an IFI control system and you won't have to wait 2 minutes to use your bathroom :P - Chris is me [more]
Unread 23-12-2012, 16:08
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Re: pic: Catalyst 2012
Originally Posted by Jay Money 1058 View Post
Just bought the game and I'm playing it for the first time, so what are some strategies for getting the high scores you guys are talking about? (meaning robot configurations, strategies, etc.)
If you check out this video then you can see my strategy. Not my best match. Sorry for the poor quality.
Unread 23-12-2012, 19:19
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
I can't wait to get it
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 24-12-2012, 17:27
Chris is me's Avatar
AKA: Pinecone
Originally Posted by bobby5150 View Post
72 point hybrid is my best... We'll have to battle it out at the expo this year! Might be fun. Whats your setup? and do you use the xbox controller?
I just ran the software on my RPI stock Lenovo W500. I bought the Xbox version since my computer overheats so $@#$@#$@#$@# much now I couldn't play anymore.
Originally Posted by O'Sancheski View Post
That was you before your computer froze and I think my high score is around 180 or so
Oh wow that was frustrating. There are three balls in transit for 9 more points. I easily had time to take the penalty and hit the red bridge for 6 more and then a balance for 25 total points. If I was lucky I'd get that stray ball and score a 1 pointer from the bridge, but even if I didn't, I would have been the record holder at 193 points.
Robot layout - mecanum drive, layup, any long range turret, blue alliance. the latter is important because the PID for the turret only spins in one direction, so being on the blue alliance lets you start shooting in hybrid much faster.
Auton strategy - immediately begin strafing to the left and back while shooting. Once you're done shooting, keep strafing toward the bridge while you spin the drive base, then grab the bridge. Get three balls, then LET GO OF THE BRIDGE and shoot, rinse and repeat until you get a 54+ point run in.
Teleop - there are two ways to do this. One way is to start a cycle like Sanchez did. Score three, slam to the left, grab the balls as they return, score, repeat. With practice this is a good way to get past the 120 mark. What Brendan does is waits for balls to idle into the bridge, takes the penalty, and scoops them all from the same place in one blow. This can be faster but it takes more finesse since you can't see what you're going for. My strategy blends the two together based on how I feel, where the balls are, etc. If you let enough balls "bleed off" the alliance bridge, they will pop out of the side of it in a perfect Pac-Man line for you to intake.
Generally for scoring, the closer you are to touching the key, the more likely you're in a sweet spot. I like playing to the spots 1717 scores from because they're close to both the alliance bridge and the ball return lane. There is a tiny spot from within the lane where you can sit and sweetspot balls into the goal but it's almost always worth it to just strafe into the key and score there.
While you want to use the Layup elevator because it's the fastest and least jammy, you don't actually have any incentive to raise it up. It does not give you more distance - it actually makes it slightly more likely for a ball to glitch out of bounds. The only exception is at the end of the match, if you have balanced, extend upward and shoot your balls off and there's a chance they will make the 1 point basket.
Once you get bored of doing absolute high score, make up challenges for yourself. I like using 8WD / Layup / Short Range Turreted, doing an alliance bridge auto, and tipping the Co-Op bridge away from me. This makes for a fun, 469 or 2056-style "bump jump" full field game which can be more fun to play if you don't mind a frustratingly low score If anyone wanted to compile unofficial little challenges with different types of bots, I'd be all for it.
Unread 24-12-2012, 19:16
Twest3259 Twest3259 is offline
Murray State University Student
AKA: Travis West
FRC #3843 (RoboRacers)
Twest3259 is an unknown quantity at this point
Challenges:
1)4WD/human loader/any turret Score above 30 in a 1v0 match.
2)any drive/no hopper/no turret Score by ramming balls into the the in front of goals and bouncing them into the one point goal.
3) Balance with at least 45% of your robot off the side of the bridge
4) Get outside of the playing field and score a shot from there. (i've done this once with the robot completely tipped over)
5)shoot only from the opposing alliances side.
That's all i can think of right now.
Unread 24-12-2012, 22:49
Robby Unruh's Avatar
Robby Unruh Robby Unruh is offline
*insert random dial-up tone here*
FRC #3266 (Robots R Us)
Robby Unruh will become famous soon enough
Originally Posted by Twest3259 View Post
Challenges:
Not 100% here, but doesn't an opposing alliance robot need to be scoring in order for you to load from the human player?
[Robots R Us #3266]
2015: Georgia Southern Classic (Winners / Thanks 1319 & 1648!), Queen City
2014: Crossroads, Queen City
2013: Buckeye, Queen City, Crossroads
2012: Buckeye, Queen City
2011: Buckeye
2010: Buckeye
Unread 24-12-2012, 22:51
Littleboy Littleboy is offline
FF: The Yellow Alliance (TYA)
Littleboy has a spectacular aura aboutLittleboy has a spectacular aura aboutLittleboy has a spectacular aura about
Why don't you just sit in the alley and get loaded by the human player and just keep shooting from there?
Unread 24-12-2012, 23:19
AKA: Travis West
That's part of the challenge it's hard enough to get balls in the game with another alliance partner, but with this set up you have to ram balls into a fender and send them into the air and catch them in your hopper. until of course you make seven shots then you can continuously load from the opposing alliances lane
Unread 25-12-2012, 00:21
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Another question: is there any benefit of having mecanum over swerve? (in the game, not in real life)
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 25-12-2012, 02:03
AKA: Pinecone
Swerve is slower and can't spin while translating. The game also does a good job of mimicking how strafing can reorient the drive base when you didn't want to, which excaberates this problem.
Unread 25-12-2012, 11:45
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
195 is my highest score in a 1v0 match. My strategy is very simple do coop bridge in auto, quick clean up after auto, then all the balls corral at the blue bridge. Drive straight, lift up, shoot the three while moving, then go back for more.
1058 PVC Pirates 2016 - xxxx
Unread 25-12-2012, 15:30
Division by Pirates
Joe and Chris: thanks for the advice, you guys increased my high score from 40 to 130 in two days!
Unread 29-12-2012, 00:14
AKA: Brendan Browne
New high score. 199! OH so close to breaking 200!
