Go to Post The minute humans begin depending on robots for anything in their daily routine is .... well, let's just hope people "in it for the lulz" don't take notice. - JesseK [more]
Unread 25-12-2012, 17:05
Re: 3D Printers
Originally Posted by ksafin View Post
Wow, the nozzle has to be that close?
You know.. this is starting to make sense.
Perhaps the reason why the top layers turn out better is because at that point, the height of the object we're printing is > 5 mm, and thus the nozzle can get super close to it. Whereas the first few layers are super far from the nozzle and thus turn out noodl-ey.
Exactly!
What's happening is: You're starting so high up that the material won't stick. But, what does stick forms a base. As you get closer to the head, the material sticks better, and forms the shape better. So by the end of the part, it looks really good. But at the beginning, ugh.
I've seen that when I've pulled material from one part in a 4-part build--eventually, I got high enough that it wouldn't act up, then it built almost normally, then other stuff happened (that I won't go into here).
Use that height-adjustment screw set--it's your friend--but once you get good parts, you don't want to touch it unless you absolutely have to.
Unread 25-12-2012, 17:40
steinra's Avatar
steinra steinra is offline
(KG7KEO)
AKA: Randy Steiner
FRC #5461 (V.E.R.N.)
steinra is on a distinguished road
Re: 3D Printers
As you get into this a little further take a look at skeinforge. it is a bit more complex, but if has some more features over slic3r. One of the things it can do is print a raft which is a couple of layers of plastic that is used to offset the part. When I had some initial layer issues the raft really helped make some great parts. But after really tuning it, I don't need it very often.
Good luck, looking forward to seeing your parts you produce.
Randy Steiner
2014-2015 FIRST Team 5461 - Coach
2011-2014 FIRST Team 4106 - Head Mentor
2007-2011 FIRST Team 1891 - Mentor
