Go to Post Celebrate your failures as well as your successes. - Taylor [more]
Unread 23-12-2012, 21:59
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Custom Control Box
We found a cypress control board in our storeroom and we are interested in making a custom control box opposed to using just joysticks. How would we go about doing so if we program in LabView?
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 23-12-2012, 22:08
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Custom Control Box
I would recommend using this rather than the Cypress. You can wire buttons switches, etc. to it and it will appear as a joystick to the PC.
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 23-12-2012, 22:28
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
I echo that sentiment many times over. Our team had been using the Cypress chip and it wasn't that the chip was hard to use, but with the extra programming and firmware, it was just more of a pain. I'm really a huge fan of the eStop board and used it all last season (and will again this season). It programs exactly like a joystick, which makes it really easy. Plus, if anything were to happen to the board, I could have substituted a joystick in a pinch. (although the little board did not / would not break).
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 23-12-2012, 22:31
ferret_guy ferret_guy is offline
AKA: Mark Omo
FRC #1703 (RATS)
ferret_guy is on a distinguished road
if you want to work with the cypress board this is the quickstart guide
Unread 23-12-2012, 23:15
Greg Young Greg Young is offline
Science Enabler
FRC #0587 (Hedgehogs)
Greg Young has a spectacular aura aboutGreg Young has a spectacular aura about
We've done this the last two years and it has worked well for us. It's been most of a year since I did this so the details are a little fuzzy.
You need to get a Cypress Carrier board from either AndyMark or eStop to make connecting switches and potentiometers much easier.
First you need to download the proper firmware to the Cypress board. The instructions are in the 2012 control system quickstart
http://www.usfirst.org/sites/default...ystem_RevA.pdf starting on page 39.
Once you've run through the instructions and your driver station sees the board you can start by wiring up a switch. The digital inputs have pullups so you ground the input to get a low. Check on the driver station enhanced i/o to make sure that flipping the switch changes the input.
Look in WPI Robotics Library -> Driver Station -> Enhanced IO for the vi's that will get the digital and analog input arrays. You can get the input you need out of the array.
This is the quick and dirty version since I don't know how familiar you are with the board or electronics in general. Ask if you have any questions.
To invent, you need a good imagination and a pile of junk. -- T.A.Edison
My wife says I must need to work on the imagination thing.
Unread 23-12-2012, 23:44
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Another option that's cheaper than the estop board is highlighted in this paper.
http://www.chiefdelphi.com/media/papers/2666
It was very easy for us to use.
Unread 24-12-2012, 16:44
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Thanks guys for all the info.
Allen: Is the Teensy compatible with the Joystick VIs within LabView?
Unread 24-12-2012, 19:12
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Throwing some more stuff out there, you could always check out a place that sells arcade/fightstick parts like http://www.focusattack.com/
This PCB looks like it would work fine as a detected PC joystick but I have not used it: http://www.focusattack.com/toodles-c...i-console-pcb/
Unread 24-12-2012, 19:30
ming08108 ming08108 is offline
FRC #4795
ming08108 is an unknown quantity at this point
I don't know much about this stuff, but a while back I saw this on kickstarter.
http://makeymakey.com/
Perhaps you could control your robot with bananas?
Unread 26-12-2012, 22:46
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
inkspell4 will become famous soon enough
Or you could use the new arduino leonardo/micro/due they now all allow for usb emulation and there are arduino vis that can be downloaded for labview
Chesapeake Regional : 2013, 2012, 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
