Go to Post yes, we've gone over every possible idea multiple times. No, we're not going to stop. Welcome to FIRST. - logicalyrandom [more]
  #31   Spotlight this post!
Unread 27-12-2012, 03:29
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Re: Wildstang 2012: After The Game
Originally Posted by MICHAELABICK View Post
Poly cord is sold on mcmaster by the name urethane belt. Some teams use the round belt and some use the flat belt. Basically, you buy the polycord and install by cutting the belting to length(a little short so that you get tension on your belts) and weld the two sides together with heat(we have a polycord welding set, but it's really not needed. I've heard of a flame or a soldering iron working well). Our team used the round belt for 2012. We machined pulleys out of ABS to make sure that the belt wouldn't move. Many other teams have similar or the same way of keeping it in place. I've also heard good things about flat belt from teams like 341. Apparently if you wrap your shafts in electrical tape where you want your belts to stay the belts will actually walk back to their places if they get moved.
You can also get small metal pieces that are inserted into each end of the cord to hold it in a loop
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
  #32   Spotlight this post!
Unread 27-12-2012, 04:11
FRC #1836 (MilkenKnights)
That's for the hollow polycord. Most teams that I know of use the solid cord, and it's honestly not that hard to weld(even without a special belt welder). We actually used a soldering iron before we got our belt welder and the welds held up the whole season. The belt welder makes the welds a bit cleaner however.
  #33   Spotlight this post!
Unread 27-12-2012, 04:28
Chris is me's Avatar
AKA: Pinecone
Hollow is a touch easier to maintain, just since you don't have to re-weld each belt when you're tightening it and it's easier to install a barb in place than it is to re-weld a belt in place. I think I'm sold on flat belting from now on though.
  #34   Spotlight this post!
Unread 27-12-2012, 05:52
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
That's interesting. Electrical tape will stop them from walking? Defiantly will have to invest in some of those! Haha
  #35   Spotlight this post!
Unread 27-12-2012, 10:25
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Great videos, thanks for sharing.
Video 4 would not play on my mobile (iPad), the rest played fine.
The views expressed are mine and should not be construed to represent the views of anyone else.
  #36   Spotlight this post!
Unread 27-12-2012, 11:41
AdamHeard's Avatar
Lead Mentor
Polycord doesn't require maintenance, and welding in place isn't that hard. Granted, our team has used polycord in excess.
We also want to switch to flat belt, but we have so much belt left over from 2009....
