Go to Post "Wow, smells like... physics" - Anna B. [more]
Unread 27-12-2012, 02:38
shawn.schwartz's Avatar
shawn.schwartz shawn.schwartz is offline
Lead Systems Engineer
FRC #0004 (Team 4 ELEMENT)
shawn.schwartz is an unknown quantity at this point
Learning Simple PID
Hello CD,
Can anyone please post tutorials or working sample Java code for someone learning PID loops and gyro programming. Iterative or Command Based Java is good! Thank you so much.
Shawn Schwartz
Programming/Head of Website & Media, Team 4 ELEMENT
team4element.com
"Innovation distinguishes between a leader and a follower." -Steve Jobs
Unread 27-12-2012, 12:57
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Re: Learning Simple PID
I know this is silly, replying to a member of my own team, but here are a few links:
http://www.chiefdelphi.com/forums/sh...d.php?t=106082
http://www.chiefdelphi.com/forums/sh...hreadid=110220
http://www.chiefdelphi.com/forums/sh...90&postcount=5
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
Unread 27-12-2012, 15:02
AKA: Brad
#0190 ( Gompei and the Herd)
Also check out http://wpilib.screenstepslive.com. There is a bunch of documentation that was posted yesterday and more coming as fast as we can write it.
Brad
Brad Miller
Robotics Resource Center
Unread 27-12-2012, 16:02
Thank you for the helpful links!
The main goal I want to accomplish with these resources is to implement a drive straight system with our tank drive code. I am having trouble figuring it out. Essentially I want to use the gyroscope to run and check if the robot is zeroed, (when in a "drivestraight" command), so that if it comes out of alignment, then it will "re-zero" itself, and continue driving straight.
Has anyone produced a java method for doing this yet, that they would like to share?
Thank you.
Shawn Schwartz
team4element.com
Unread 27-12-2012, 16:06
This might give you some ideas:
http://www.chiefdelphi.com/media/papers/2438
edit:
I should have mentioned: If your vehicle is not driving straight when so commanded, check the hardware first before trying to correct it in software. Check drivetrain alignment and friction on left & right sides. Check your wiring to make sure you don't have asymmetric voltage drops left vs right. Check the left & right motors to make sure they have similar performance curves.
Unread 27-12-2012, 18:39
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
What's the general opinion on using PID through the Jaguars vs using it through WPILib?
And what's the correct procedure for PID (either distance or speed) when you have one encoder on each side of the drivetrain? Average the two together, or command them both separately?
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 27-12-2012, 20:37
It depends on what you are trying to achieve.
Unread 28-12-2012, 09:16
DonRotolo's Avatar
Back to humble
FRC #0832
Generally, you pick one parameter to control and then control it. Trying to control two parameters will lead to conflicts.
Using the built-in PID in the Jaguar allows you to control that Jaguars output. If you want to control the outputs from multiple Jaguars quasi-independently, such as in the drivetrain, you would need to do it at a higher level such as in your cRio.
