Go to Post I jumped up and yelled when I saw both my teams in the same division. Less running for me in the pits. Thank you, Great Homie in the Sky! - Barry Bonzack [more]
Unread 15-12-2012, 13:05
kbocheltree kbocheltree is offline
FRC #4122
kbocheltree is an unknown quantity at this point
WindRiver Plug-in for Command Based C++
We are new to using C++ on the robot this year (only our second year in FIRST Robotics) and we wanted to try the Command Based C++ approach. When we went to add the C++ Command Based Plugin to WindRiver, no plugin was added and it did not appear on the drop down menu. Is the command based plugin still at the same location? Anyone else have issues with getting it installed in the WindRiver environment?
We would like to look at it before the 2013 season starts.
Any other teams out there using the Command based approach? Comments?
Thanks!
Unread 18-12-2012, 18:28
phynix phynix is offline
FRC #3130 (ERRORs)
phynix is an unknown quantity at this point
Re: WindRiver Plug-in for Command Based C++
Just curious, is there a difference between 'command based' C++ and 'standard' C++? Is there such a thing as non-command based C++?
Anyway, we have C++ running on our robot. I think something similar happened with us; I can't recall completely since it was so long ago. I downloaded windriver and installed all the updates--but the updates weren't the correct version. (And we had a host of other problems with other C++ related things, such as the imaging tool not working on our crio--all which are fixed), but my advice would be to double check that you have the latest (2012) versions of everything. FRC2012UtilitiesUpdate2.0.zip would help (a simple google search should reveal the download link).
EDIT: Disregard everything I said. I don't want to delete this post, but to the people who come across this thread on Google and want to know about command based C++, here you go: http://firstforge.wpi.edu/sf/go/doc1297?nav=1
Unread 27-12-2012, 21:29
nightpool's Avatar
nightpool nightpool is offline
robotRectifier
AKA: Evan
no team (formerly of CORE 2062)
nightpool is on a distinguished road
"Command-based" c++ is a library provided by First/WPI as an alternative style of programming the robot. It rests around making "Subsystems" that then do "Commands".
Proud alum of CORE 2062.
www.core2062.com
Unread 27-12-2012, 21:39
"Command-based" is a software architecture, not a language.
Unread 31-12-2012, 10:54
Doron_Sivan Doron_Sivan is offline
FRC #4590 (GreenBlitz)
Doron_Sivan is an unknown quantity at this point
Hi,
We are, GreenBlitz 4590, using the C++ Command-Based Robot.
You can download the plugin through the windriver. You need first to switch it to Anvanced development and then click on the "Help" tab.
Basically it is all written here: http://firstforge.wpi.edu/sf/docman/...tation/doc1297
We've also uploaded some tutorials about the command-based:
https://www.youtube.com/watch?v=avhnXSmONyE
Hope I helped!
Unread 02-01-2013, 09:04
Gadeer Zbedat Gadeer Zbedat is offline
FRC #1946 (Mishka Monster)
Gadeer Zbedat is an unknown quantity at this point
Hello everybody
I need help in programing the Jumper . In order to see the voltage in the computer drive station.
