Go to Post Maybe the lesson the internet is trying to teach us is to "Think before you post, the machine is watching and never forgets..." - IKE [more]
Unread 27-12-2012, 23:41
Jared Russell's Avatar
Taking a year (mostly) off
Re: Dealing with low resolution data for speed PID
Problem with measuring elapsed time between consecutive encoder pulses is: manufacturing tolerances of the spacing of pulses on the encoder wheel can result in an excessively noisy signal if you measure only one pulse.
I have found that the most common source of this problem with encoders is that the A and B lines are not exactly 90 degrees out of phase and I am trying to measure the time between two consecutive transitions in "x4" mode (rising A -> falling B for example). I have had good luck with measuring successive transitions in "x1" mode (rising A -> rising A) because the disks themselves are usually pretty well made(at least in the case of US Digital S series and Grayhill 61/63 series optical encoders).
Worst case you can average the last N measurements and be able to trade off phase delay with smoothness.
