Go to Post If I was a balding man, and Dean Kamen signed MY head, I'd immediately make my way to the nearest tattoo parlor and have them make it a permanent fixture. I wouldn't have washed it off! Just saying. - Carolyn_Grace [more]
Unread 22-12-2012, 22:54
iyermihir iyermihir is offline
FRC #0649 (Saratoga MSET)
Team Role: CAD
iyermihir has a spectacular aura aboutiyermihir has a spectacular aura about
Mounting a Toughbox
I would like to use a Toughbox on a frame made out of 2x1 box tubing to direct drive one of the wheels, but I am not sure how to attach it to the frame. I have modified the plates on the Toughbox so that I can put the bottom two bolts that hold the Toughbox together through the tubing. Are two bolts enough or do I need more?
-Mihir
Unread 22-12-2012, 23:15
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Re: Mounting a Toughbox
Two bolts should be plenty. I say this from both past experience with our robots as well as my limited engineering intuition.
Past Experience
--Every year, from 2009 to 2011, we direct drove wheels through a supershifter by mounting the plate with two 1/4-20 bolts. We had no problems at all with this.
Limited Engineering Intuition
--1/4-20 bolts, for the most part, are overkill when it comes to loads experienced in FRC. I know that other teams, such as 973, have standardized their bolts at a 10-32 (or -24, I forget) for that very reason. So, if you are having any worries, use a 1/4-20 and be secure in your decision for doing so, as it is a safe choice. If you want to see some further detailed engineering information, check out the link below:
Here
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
Unread 22-12-2012, 23:35
Team Role: CAD
Thanks for the adivce.
Do you have any pictures of your setup?
-Mihir
Unread 23-12-2012, 00:44
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Two bolts should be fine, but only if the outer end of the drive shaft is supported, especially since with direct drive you'll have a good chunk of the robot weight sitting on that wheel.
Unread 23-12-2012, 01:02
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Yes, two bolts is plenty to secure a toughbox to a frame.
If you have some unused Kitbot lying around, then some of the hex tube between the toughboxes would not be a bad idea. Our team mounted our toughboxes from last year with some aluminum angle, and the extra bracing provided by the hex tube really helped.
Unread 23-12-2012, 01:37
AdamHeard's Avatar
Lead Mentor
Its not the strength of the bolts in question here, but rather the overall geometry of the joint.
2 Could be plenty strong, or a total failure. If you post a picture we could give you better help.
Unread 23-12-2012, 01:55
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I would make the decision based on what was actually taking the load. If you were using thick wall tubing (1/8" or so) and supported the output shaft with bearings pressed in the tubing, go for it. On the other hand, if the two screws were going into thin walled (1/16th or less) tubing, and were the only thing supporting the gearbox (and the weight of the robot), I'd be a bit more cautious.
We did something similar in 2010, except we didn't direct drive the wheels. In addition to two bolts going through the Toughbox to tubing on either side, we used this to help support the gearbox.
Keep in mind, like AdamHeard said, if you give us more information, we can give you better advice.
-Plutarch
Unread 23-12-2012, 14:52
Team Role: CAD
I attached a side view and a front view.
The tube is 2"x1"x.125"
Thanks for all of the help.
-Mihir
Name:	TBox front.JPG
ID:	13344  Click image for larger version
Unread 23-12-2012, 15:03
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Better safe than sorry on thin wall tube. I would recommend welding on a .125" mounting plate and using 4 screws for mounting. If you used only 2 screws and one became loose you will run into problems. Sometimes a little overkill is a good thing.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 23-12-2012, 16:18
pfreivald's Avatar
AKA: Patrick Freivald
I'm a big fan of overkill especially when it comes to drive train. If you can't drive, you can't play!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 28-12-2012, 10:55
waitwhat?'s Avatar
waitwhat? waitwhat? is offline
Driver Coach
AKA: Bunca
FRC #0747 (Flight Crew)
waitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant futurewaitwhat? has a brilliant future
I agree with this whole heartedly, the drive train keeps you in the game.
That being said, a good moto is "When in doubt, make it stout" meaning if a joint or mechanism looks questionable, beef it up until you feel comfortable with it.
You might want to capture the end of the drive shaft in a bearing, will help keep your transmission and drive shaft lined up as well as distribute some of the robot weight a bit.
Unread 28-12-2012, 17:36
FRC #1836 (MilkenKnights)
True, but I don't think it is needed. All the teams that do WCD have been cantilevering their drive shafts and have been fine for years(remember, their gearboxes are also sticking out more due to the space needed for the shifter and the sprockets). However, if you already are running the tubing on the other side you should but a bearing just because you can. I would consider though if you really need that outer tubing, as it can be a lot of weight that is not really needed. The joint can also be made stronger if you move the bolts higher in the tube.
