Go to Post Honestly I'm looking forward to just seeing all my friends again, that's what FIRST is really about to me. - Barry Bonzack [more]
Unread 28-12-2012, 14:53
devixluvic devixluvic is offline
devixluvic is an unknown quantity at this point
Need help identifying gearbox
Hello all here,
I am working on a project and need a certain type of planetary gearbox for a CIM. I have a picture of what it should look like:
However, I can't find a gearbox like that anywhere online. It's supposed to have a 1:4.5 gear reduction, or something around that.
If anyone knows what model gearbox this is and could help me, it would be very much appreciated!
Thanks!
Devix
Unread 29-12-2012, 06:29
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Need help identifying gearbox
I'm curious as to how this is supposed to mount onto a CIM; CIMs (or at least the ones I've seen) don't have star shaped splines. Also, this seems fairly thin for a planetary gearbox - are you sure this is the entire gearbox?
Unread 29-12-2012, 08:19
Gdeaver Gdeaver is offline
FRC #1640
Some thing like that is used on electric scooters. Some bike shops got into the scooter craze and may have parts.
Unread 29-12-2012, 10:03
AlexH AlexH is offline
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
http://products.matexgears.com/viewi...lbs-?forward=1
looks like one of these
My Instructables
Unread 29-12-2012, 13:51
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Little known fact: in the early days of CIMs, they didn't have the 8mm keyed shaft that we know today. They shipped with a gear shape cut into the CIM shaft, apparently to integrate into a gearbox. This is quite probably the star shape spline needed to fit into this carrier.
Of course, putting the CIM in that hole wouldn't be very useful, because this would cause a decrease in torque, not an increase, given that hole is in the planet carrier, not in the sun gear. On the other hand, it might be the case that the star shaped CIM shaft was the sun gear in this gearbox.
I have no idea what planetary this might be. I might hazard a guess that this was part of the origional application for CIMs. A BaneBots P-80 might be what you're looking for, although they only have 4:1 and 3:1 single stage reductions.
-Plutarch
Unread 29-12-2012, 14:06
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The CIM was originally used in a power jack for lifting RV tongues. The splined version was known as the Atwood or Chiaphua motor.
It used spur gear reductions, so this gearhead is definitely not from the original application
2001-2004: Team 100
2006-Present: Team 254
Unread 29-12-2012, 14:41
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
That gearbox has nothing to do with a FIRST CIM motor. It is a 75mm planetary for Currie electric scooters. Google "currie scooter planetary gear".
