Go to Post We don't want "The Flame Heard 'Round the World"... - Andrew Blair [more]
Unread 17-01-2003, 17:18
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Help with Inventor Assembling
I am new in Inventor, but already have a very good understanding of the program. I can draw anything I want to, and make everything look great. The only thing I have problems with is assembling.
Attached I have put a picture of part of the ramp I am making for my field in Inventor. I have 3 ipt parts, the 5 long planks, the 2 4ft planks, and the 4 legs. (As you can see in the picture). I need to know how I can successfully place all these parts together in an assembly. I have them all fixed up how I want them to, but I can't get them all aligned up with the constraints. Is there an easier way to contrain all of the parts?
Is there a way to constrain the 2 pieces at more than 1 point so it isn't crooked? Any good tips for assembling?
Thanks!
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 17-01-2003, 17:35
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Since i dont have a copy of Inventor in front of me this may be a little vague. One thing it looks like you need to do is the "flush" constrain. It's under the mate constrain (the clicky box thingy on the bottom right corner), this should help you get them all lined up.
Purdue Alumni
Cummins, Inc.
Unread 17-01-2003, 17:41
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
What he said
You can use the Mate/Flush constraint, along with an offset, to line everything up properly. Alternately, you can mate three edges and use offset to achieve the same result.
Generally speaking, however, I think you'd have the best results and the least confusion if you mated surfaces rather than edges.
--Madison--
...down at the Ozdust!
Unread 17-01-2003, 18:01
AJ Quick's Avatar
Well "flushing" works perfectly, I was doing everything in "mate" which really can't have more than 2 things mating to, while "flush" could.
Thanks!
Unread 18-01-2003, 09:45
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
Talking there's lots more fun to be had
yes and after u finished there is tons more /sarcasm FUN/
assemblies u can do. i built and arbor press and when u turn the handle the press moves...then all the pieces fly off the screen.... i really think autodesk should change this. btw did u get the copper wire on right thpse tangents are tricky
over and out
matt
1024
