Go to Post ...Of course, all the scales in the world won't help you if your robot is 135lb two nights before the ship date... - J Flex 188 [more]
Unread 12-30-2012, 09:30 PM
Azrathud's Avatar
Azrathud Azrathud is offline
Computer Nerd
AKA: Bryce Guinta
FRC #2945 (BANG)
Azrathud is on a distinguished road
Tool to Manage Static Computer IP
I made a script to toggle between a set static IP and using DHCP in Windows. I hope it's useful to someone.
You can always find the latest version at manitourobotics/tools/windows/
To setup:
  • Download and extract attached zip to this post
  • Install python2 if you don't have it
  • Copy config.example.txt to config.txt and configure static_ip and interface_type
  • Create a shortcut to net-connect.bat by right-clicking on the file and clicking "Create Shortcut"
  • After creating the shortcut, right click on it and click properties. In the shortcut tab, click advanced... and check run as administrator(this program always needs to be run as admin). Click ok * 2
  • Drag shortcut to your start menu for fast switching
Changelog:
1.2:
  • Rename config.txt.example to config.example.txt for easier renaming
  • Add Windows line endings to config.example.txt, so notepad doens't display the file in one line
1.1:
  • Add config file
  • Less arcane output
  • Better error handling
Unread 12-30-2012, 09:33 PM
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: Tool to Manage Static Computer IP
Oh yea! This will be great. I've had too many problems with our programmers forgetting to reset the IP settings, and too many noobs forget how to do it.
Unread 12-30-2012, 09:48 PM
http://www.chiefdelphi.com/forums/sh...ad.php?t=72308
http://www.chiefdelphi.com/forums/sh...ad.php?t=75780
Unread 12-30-2012, 10:36 PM
Azrathud's Avatar
Computer Nerd
AKA: Bryce Guinta
FRC #2945 (BANG)
I did see those posts. I wanted something more flexible, and something requiring me to only click on one file(as in a toggle).
Unread 12-31-2012, 11:30 PM
Azrathud's Avatar
Computer Nerd
AKA: Bryce Guinta
FRC #2945 (BANG)
For some reason I can't edit my posts. I made another tool that just shows network interface information.(I hate manually checking the Network adapter every time I'm curious about my current IP status)
Unread 12-31-2012, 11:52 PM
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
You could just go Start->Run->type 'cmd' (usually already typed in since I almost certainly used it last) -> ipconfig /all
Same thing for the config. I used to write Batch and Perl scripts to do it, then I got lazy and just remembered the command to type ('netsh interface ipv4 set address "Local Area Connection" static 10.0.33.217 255.0.0.0'). Roughly the same number of mouse strokes (which are highly more time-consuming than keystrokes), especially if I don't have the folder with the batch file open or I'm not on my computer.
My best solution is to just use WiFi only for real networks, and use wired Ethernet only for robot networks. But, in case I have to break this, then I can just type netsh and be done.
But, if you do still want to do it this way, it should be possible to do entirely in a shell script, reducing dependencies on a foreign machine to zero.
Kettering Motorsports
Unread 01-01-2013, 12:16 AM
You have a 24-hour window after posting to edit or delete. Think of it as a 24-hour-cure epoxy.
Unread 01-01-2013, 12:26 AM
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Along with Andrew's info you should be able to achieve a toggling script by using an environment variable.
Unread 01-01-2013, 01:19 AM
Azrathud's Avatar
Computer Nerd
AKA: Bryce Guinta
FRC #2945 (BANG)
ipconfig /all shows interfaces I don't care about. I really wanted a way to just show basic interface information that doesn't make me hunt for the information.
With using script to toggle between static and DHCP, I remove any errors that I may make with signaling what static IP I want(which avoids IP address conflicts), and it saves time and patience for me.
Sometimes my team needs the robot to be using the wireless network for increased mobility(although I do generally use wired for the static internet-lacking network and wireless for internet access), and I use my personal computer to work on the robot, so, at the end of the day, I don't want my wired interface to be set to a static IP.
I opted for python over solely batch(thus not reducing the dependencies to zero) because batch makes simple things like storing the output of a program into a variable painful. I honestly tried to use only batch, but I couldn't bear using it after a point.
Using an environment variable sounds kind of hackish; the only way I could imagine being able to make a toggle of sorts would be to stuff practically a batch script into a variable that I execute. I really don't want to use the command-line directly to execute my program because then I would have to worry about editing the path variable to where I store the batch files, and I would need to run the prompt as administrator to change my IP, and I would need to type in the program name, as to apposed to just hitting the windows key once, the down arrow key, and then enter as I have it now.
The work is done; feel free to use it or not.
Unread 01-07-2013, 04:26 PM
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Been a little curious about this, but haven't gotten around to trying it yet, but can you simply enable DHCP and make reservations for the CRIO MAC address (and camera(s) if needed)?
Seems like an even nicer solution than the batch/script files (which are a huge improvement over manually switching). The only downside is lost learning opportunity for the kids doing it.
Save the router config once you do it, and reload the config after each match
Unread 01-07-2013, 07:46 PM
Lightfoot26's Avatar
Lightfoot26 Lightfoot26 is offline
Just Out For A Rip, Bud...
AKA: Seth Lightfoot
FRC #1625 (Winnovation)
Lightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really niceLightfoot26 is just really nice
also... http://www.chiefdelphi.com/forums/sh...16#post1089016
Winnovation Team 1625 (2010-??)
  • Electrical/Programming Captain (2011-2013)
  • Auxiliary Driver (2012-2013)
  • Team Captain (2013)
  • Alumni (Graduated May 2013)
  • Electrical and Programming Mentor (2014-??)
Unread 01-07-2013, 07:51 PM
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
The driver station program should automatically set your computer's IP for you when you start it up, as long as you've properly configured the team number and NIC. I don't see the need for a different program to set the IP...
Unread 01-07-2013, 08:19 PM
computerish computerish is offline
FRC #0619
computerish is an unknown quantity at this point
Our team decided it was easier to just have two network interfaces. We picked up cheap network cards (you can find them for ~$10 each) and simply added a second interface card to our lab computers. Set the static IP on the robot interface and DHCP on the other one.
Bonus tip: You can buy a short ethernet cable and a straight-through double female RJ45 connector to extend your ethernet jack out to the edge of our desk. Helps a lot if your computer sits back under the desk.
Unread 01-07-2013, 10:38 PM
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
This is great.
Also you may use the 2CAN firmware utility to change ip's and switch between static and DHCP.
http://www.crosstheroadelectronics.c...tility_1_4.zip
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
