Go to Post Mentors can always use mentoring. - JaneYoung [more]
Unread 30-12-2012, 01:45
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: pic: WCD
Or you could just do GT2 belts, C-C +.003-.006 and not worry about it?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 30-12-2012, 02:04
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: pic: WCD
Originally Posted by DampRobot View Post
I take your point about the 973 blocks being easy to machine, but I just can't get around the fact that there are 3 pieces that need to be machined instead of 2. I guess my question comes down to this: why do the bearings need to be in one piece, and if they aren't, what happens? Joey's response seemed to be that although this can cause the wheel to be out of alignment, nothing terrible happens.
On the other hand, if two piece (rather than 3 pieces) are hard to keep aligned, and this misalignment will significantly impact performance, a 973 (or 254, for that matter) style bearing blocks are the best option. I just wasn't really aware that this could be a large problem, and want to make sure that we don't make any drivetrain decisions that we'll regret next year.
Sorry for hijacking the thread, I just want to learn a bit more about the ins and outs of WCD bearing blocks, like the ones featured in this design.
The advantage of pressing both bearings into the same bore is that they're definitely lined up straight. You don't need them to be perfectly in line, but then you're going to wear out your bearings much more quickly, you're going to sap efficiency, and if its bad enough, the whole thing will seize up. You'll be able to see and feel the improvement of having the bearings in the same bore, but if its just impossible for you to do it that way, it can still work, just not was well
Unread 30-12-2012, 02:24
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: pic: WCD
Just to note, 696 has always done two separate bearing blocks machined from 1/4" x 2" flat bar held inline by nothing more than the axle through bearings and 4 bolts and we've never had a problem. Much less machine time and material cost. Although, we may go for the fitted-tubes style next time, just to try it out.
Unread 30-12-2012, 13:35
the.miler's Avatar
the.miler the.miler is offline
taking a break
AKA: Miles Chan
FRC #0846 (Funky Monkeys)
the.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of light
Re: pic: WCD
Alternatively, you could make your bearing block out of a single piece of 1.25" wide by 2" high at 1/8" thickness tube, available at onlinemetals:
http://www.onlinemetals.com/merchant...269&top_cat=60
I know it's 6063 aluminum; our drivetrain was made with the stuff last year, and it was just fine to machine.
Bore your bearing hole and a couple of screw holes, and then lop off the top of your tube to make a C-channel like piece. Slide it onto the robot, tighten down your screws, and you're good. Our team used the system on previous robots before we moved away from the cantilevered drivetrain design; while I cannot personally attest to its effectiveness, as it was before my time, our mentors recall the solution as doing a fantastic job. Since we intend to return to cantilevered drive this year, we have of course revamped the design; a screenshot is here:
https://plus.google.com/u/0/photos/1...06823682841202
All the advantages of imbedding your bearings in a single piece, without having to make three different bearing block pieces. I thought it was genius when I first saw it, and the material is readily available.
Member 846 The Funky Monkeys 2010-2014
Team 846 Highlights 2014
lynbrookrobotics.com
becauserobots.org
Unread 30-12-2012, 22:29
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
Re: pic: WCD
Seems like a pretty fantastic idea altogether. Have you considered using rod ends instead eye bolts for tensioning? I might be misunderstanding how your system works, but the eye bolts in your CAD seem excessively large compared to the bolts being pulled.
Unread 31-12-2012, 00:58
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: pic: WCD
This is genius
One question, so how do you keep overzealous tightening of the two black bolts from crushing your bearing block? (or am I just missing something )
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 31-12-2012, 01:05
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Re: pic: WCD
How about the idea of no bearing blocks at all?
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 31-12-2012, 01:07
Mk.32's Avatar
AKA: Mark
Re: pic: WCD
This is what we did with our off season robot. We used the correct Center to Center for 25 chain, the did loosen a bit but over 3 off season competitions but we never lost a chain.
We are looking into going to belts however for our new iteration of the drive.
Unread 31-12-2012, 01:08
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: pic: WCD
I, for one, think this is really the best solution, but it takes too much guts for me to try out. We didn't prototype a exact c-c drive in the offseason, and there's too much potential for failure for my comfort level. I would need to know that we had this design in the bag (like you guys do) to use it during the season.
-Plutarch
Unread 31-12-2012, 01:43
the.miler's Avatar
taking a break
AKA: Miles Chan
Re: pic: WCD
Jose,
I clearly haven't searched McMaster closely enough. The rod ends seem like a great idea; I used the eyebolt mostly because it was the first thing that came to mind, and will work just fine, as I only need to pull on the bearing block to achieve correct chain tension. If the rod ends become necessary, I will be indebted to you for having brought them to my attention
Garrett,
Again, I was not a member of Team 846 when we first used this design, so I do not know what ferocious punishment was threatened upon those who tightened the bearing block too tight I imagine that if you put some sort of spacer inside (or stack a bunch of those cool little VEXPro washers inside), just a touch smaller than the width of the tube you are clamping with the bearing block, you would prevent the bearing block from ever being tightened tight enough to cause failure.
All you fixed C-C proponents:
Yes, I wish we could go fixed C-C . . . with belts! That would be amazing. I do not think we would ever go fixed C-C with chain, we've just had too many issues with sprockets wearing down and consequently changing the tension on the chain . . . never mind just the stretching with time. As we get a little more experience with using 7075 for our sprockets or even implementing our off-season belt drive design, we may reconsider that stance. If any of you guys try it out (or in 973's case, have), we'd love to hear how that went.
becauserobots.org
Unread 31-12-2012, 02:11
FRC #1836 (MilkenKnights)
Re: pic: WCD
I'd be scared with #25 chain and/or indirect drive.
Unread 31-12-2012, 02:56
Mk.32's Avatar
AKA: Mark
Re: pic: WCD
All I am going to say we did it: http://www.chiefdelphi.com/media/photos/38147
Ran 3 off seasons, not a single chain lost.
Unread 31-12-2012, 03:59
Re: pic: WCD
If you really need to that would probably be fine(but only if you're direct driving your centers). I just see so limited downside in going without bearing blocks. If you have the resources to spend on completely custom gearboxes then it's not going to take very long to make 8-12 973/1323 bearing blocks. Especially now with the new WCP gearboxes you can shift the resources used to make the gearboxes over to making bearing blocks that improve your consistency and efficiency.
Unread 31-12-2012, 11:57
Aren Siekmeier's Avatar
on walkabout
Re: pic: WCD
But the point is that if you simply don't need them, don't bother with the weight, complexity, cost, or manufacturing time, and the resources you would have shifted from gearboxes to bearing blocks can now be focused on something more relevant to the challenge. The question is whether you need them, and there is some solid evidence coming forward that you don't (with the usual caveat: if you do it right).
And I'm not sure what, if anything, direct driving the center wheel would have to do with an exact c-c?
Unread 31-12-2012, 13:11
Re: pic: WCD
He is concerned about losing mobility (chain popping off) when using #25 chain without bearing blocks.
