Go to Post Imagine the pressure on Dave Lavery - every time he sneezes someone assumes it's a game hint. - Gary Dillard [more]
Unread 31-12-2012, 13:11
Re: pic: WCD
Originally Posted by compwiztobe View Post
And I'm not sure what, if anything, direct driving the center wheel would have to do with an exact c-c?
He is concerned about losing mobility (chain popping off) when using #25 chain without bearing blocks.
Unread 31-12-2012, 13:59
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is online now
on walkabout
Re: pic: WCD
I still see no difference between an indirect drive with bearing blocks and an indirect drive without, since maintaining tension on the chain from transmission to first driven wheel is as simple as a slotted transmission noun. That point of failure doesn't depend at all on an ability to move wheels to adjust tension. And beyond that, the system is identical to a direct driven WCD (w/ or w/o blocks). I see bearing blocks and direct drive as two completely independent design decisions, though if there are other details I have overlooked I would be glad to hear them.
Unread 31-12-2012, 14:07
Chris is me's Avatar
AKA: Pinecone
Re: pic: WCD
With a direct drive live axle drivetrain (or any chain drive), you need a method to tension the chain. Since this isn't an indirect drive, moving the gearbox isn't an option. The most efficient way to do it is to move the wheels slightly outward or inward, hence bearing blocks.
Unread 31-12-2012, 15:36
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: pic: WCD
We had an 8WD WCD last season. The siderails were 1" x 2" x .125" rectangular tubing, and we put the bearings right into the siderails, no bearing blocks. They were designed to use exact C-to-C for #25 chain. Our thinking is that if the chain ever stretched to the point of being a problem, we'd replace it with new un-stretched chain. This served us well through two regionals. We never replaced a chain. Looking back, I think I'd have the students replace the chain at the beginning of each regional just to be safe.
See here for CAD:
http://www.chiefdelphi.com/media/papers/2752
