Go to Post I also hate it when I keep seeing this message: "You must spread some Reputation around before giving it to Andy Baker again." - dlavery [more]
  #31   Spotlight this post!
Unread 31-12-2012, 13:59
Aren Siekmeier's Avatar
on walkabout
Re: pic: WCD
Originally Posted by Akash Rastogi View Post
He is concerned about losing mobility (chain popping off) when using #25 chain without bearing blocks.
I still see no difference between an indirect drive with bearing blocks and an indirect drive without, since maintaining tension on the chain from transmission to first driven wheel is as simple as a slotted transmission noun. That point of failure doesn't depend at all on an ability to move wheels to adjust tension. And beyond that, the system is identical to a direct driven WCD (w/ or w/o blocks). I see bearing blocks and direct drive as two completely independent design decisions, though if there are other details I have overlooked I would be glad to hear them.
  #32   Spotlight this post!
Unread 31-12-2012, 14:07
Chris is me's Avatar
AKA: Pinecone
Re: pic: WCD
With a direct drive live axle drivetrain (or any chain drive), you need a method to tension the chain. Since this isn't an indirect drive, moving the gearbox isn't an option. The most efficient way to do it is to move the wheels slightly outward or inward, hence bearing blocks.
  #33   Spotlight this post!
Unread 31-12-2012, 15:36
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: pic: WCD
We had an 8WD WCD last season. The siderails were 1" x 2" x .125" rectangular tubing, and we put the bearings right into the siderails, no bearing blocks. They were designed to use exact C-to-C for #25 chain. Our thinking is that if the chain ever stretched to the point of being a problem, we'd replace it with new un-stretched chain. This served us well through two regionals. We never replaced a chain. Looking back, I think I'd have the students replace the chain at the beginning of each regional just to be safe.
See here for CAD:
http://www.chiefdelphi.com/media/papers/2752
  #34   Spotlight this post!
Unread 31-12-2012, 18:26
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Re: pic: WCD
Has anybody been able to find the CAD models for the WCP 2-speed Shifters? It doesn't look like it is yet available on the website.
Originally Posted by msimon785 View Post
We are actually not using this bellypan. It was designed more for the aesthetic of the rendering and would actually be useless because it does not prevent torsion in the frame much at all (because of the typography in the center).
Instead, we are using a waterjet 1/16" ABS bellypan with a few large pockets rather than the conventional diamond pattern.
As to the electronics, 1515's electronics for the past 3 years have utilized c-channel slides and either a reinforced corroplast or polycarbonate. We use WAGO X-comm modular terminal blocks to allow us to easily remove all the electronics in a matter of seconds. Is this level of modularity necessary, or perhaps even desired? No. However, it is a technique that has worked for our team in the past and we do intend to continue modularity in electronics in the future. It is something that our programmers and electrical students both very much appreciate as it allows them to work independently and free of debris.
The bearing blocks are very similar to the 973/1323 ones as Michael said, but with a different bolt pattern.
Please note that while this is a "standard" wcd frame, a much more recent iteration (except for the abs bellypan) is found here.
EDIT: Also, the WCP gearboxes are anodized black and colors in both this rendering and that of our latest revision are simply for the sake of the rendering. (I actually helped with the WCP renderings).
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
  #35   Spotlight this post!
Unread 31-12-2012, 18:27
FRC #1836 (MilkenKnights)
Re: pic: WCD
Both Mathew and I got it directly from RC himself. Try PMing him for the CAD
  #36   Spotlight this post!
Unread 31-12-2012, 20:02
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: pic: WCD
Seconded. RC's very good about answering email. I got my model directly from him too.
-Plutarch
  #37   Spotlight this post!
Unread 01-01-2013, 00:32
josesantos's Avatar
josesantos josesantos is offline
Mentor; Former Design Chairman
FRC #0687 (Nerd Herd) (VRC #687z) & FRC #5499 (BHS Robotics)
josesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond reputejosesantos has a reputation beyond repute
Re: pic: WCD
I haven't downloaded them myself, but it appears that the CADs you're looking for are here: http://wcproducts.net/cad/
  #38   Spotlight this post!
Unread 01-01-2013, 01:04
Gary.C Gary.C is offline
OUTWORK US
FRC #1323 (MadTown Robotics)
Gary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond reputeGary.C has a reputation beyond repute
Send a message via AIM to Gary.C
Re: pic: WCD
Correct, working on getting the rest of the missing models up, but all the important ones are there.
Each part has its CAD model on its respective page now! (Still working on getting them all covered)
Such as WCP DS: Dual Speed
http://wcproducts.net/wcp-00100/
Gary Chahal
Webmaster & Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
  #39   Spotlight this post!
Unread 01-01-2013, 13:34
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Re: pic: WCD
Originally Posted by rcmolloy View Post
How about the idea of no bearing blocks at all?
This was our approach last year also. We did do a few things to help prevent the loss of a chain. First of all our chains were all internal, placed inside the 1.5 x 2 frame rails. We changed our chains before the start of our second regional, before Championship, and again before IRI. We have had the same chains on since IRI which includes MANY hours of demos, Beta testing, drive practice, and the Ruckus.
Overall we didn't see much wear on the sprockets but the chain does stretch quite a but. We have looked at adding a chain tensioner to the system. If the chains were external I would look into a system to tension the chains.
Cutting the frame rails with exact c-c and not worrying about additional machine time for bearing blocks is nice. It gives us time to work on other aspects of the robot.
  #40   Spotlight this post!
Unread 01-01-2013, 13:41
AdamHeard's Avatar
Lead Mentor
Re: pic: WCD
There clearly isn't a correct bearing block design for all teams with all resource sets across the board.
I think the distinguishing factor is teams that know how to machine and commonly do it, and those that machine less or have a buddy, sponsor, etc... make stuff.
If a team has a manual mill in house and regularly uses it, the bearing block design we make is just as fast to make (or even faster the way we cut them) than most of the ideas presented in this thread that are less rigid and functional. Our blocks look big and to someone who isn't used to milling it might seem like a lot of material removal, but it really isn't. We could manufacture a season set within 2-4 hours (that's 20-40).
The most important aspect of a bearing block for a WCD is rigidity. When it is clamped to the tubing, there must be no slop or play.
  #41   Spotlight this post!
Unread 01-01-2013, 19:20
josesantos's Avatar
Re: pic: WCD
*emphasis mine*
Care to share?
  #42   Spotlight this post!
Unread 03-01-2013, 04:01
Design Mentor
Re: pic: WCD
Can you please explain how you are mounting your bumpers to those frame rails?
How are you attaching the bumpers to the front and the back?
  #43   Spotlight this post!
Unread 03-04-2013, 19:23
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: pic: WCD
Where can I get the CAD files for the WCP DS: DUAL SPEED Gearbox?? Idk how to download the ones from their site and use them in solid works..
  #44   Spotlight this post!
Unread 03-04-2013, 19:33
Re: pic: WCD
Did you try right click and save as?
  #45   Spotlight this post!
Unread 03-04-2013, 19:42
Cash4587's Avatar
AKA: Cooper Cash
Re: pic: WCD
Yeah.. it comes up and opens as a text document and incompatible file.
