Go to Post Look at the success of the Banebot's gearboxes this year. Cheap, light, small, and a lot of people are using them, even though their quality may be a bit questionable... Make a similar gearbox for a drivetrain (with a bit more robustness) and I think you've got a winner. - Ben Piecuch [more]
Unread 09-11-2012, 01:18
meicheng meicheng is offline
Electronics/Communications
FRC #1671 (Buchanan Bird Brains)
Team Role: Electrical
meicheng is an unknown quantity at this point
LED Issue- PMW to Sidecar
Our LED isn't working, and we think it's because we put the PMW in the wrong place. The problem is that we don't know what "the right place" is. Does anyone know whether we have to connect the PMW to a certain place on the sidecar and, if we do have to, how we would know where exactly to connect it?
We don't think the LED issue is because of the Spike, because it has worked before and has a good fuse in it, and all of its wire connections are secure (except for the other end of the PMW). But the Spike flashes orange/yellow in time to a clicking noise when the fuse is still in and when we turn on the robot. Any ideas about what's wrong?
Any documents about PMWs, digital sidecars, and Spikes would be helpful.
Helen Cheng
Unread 09-11-2012, 08:09
Re: LED Issue- PMW to Sidecar
A PWM cable connects a Spike to one of the Relay outputs on the Digital Sidecar. The Relays are labeled and the pins for them have a trough in front of them full of status lights that light up red & green when they are active.
Here is a description of the Digital Sidecar to help identify where the cable belongs.
The Spike documentation is way out of date.
Unread 09-11-2012, 18:33
JohnChristensen's Avatar
JohnChristensen JohnChristensen is offline
Professional Sparkie
no team (No Team)
JohnChristensen is on a distinguished road
Spikes MUST be plugged into the relay ports on the Sidecar to work correctly. The constant clicking may be because of a "noisy" signal on a PWM output on the sidecar port if you don't have it connected in the relay section.
Unread 12-11-2012, 01:42
I've plugged it into one randomly selected port of the relay ports on the sidecar. There is no clicking sound now, but there is no LED signal.
Does anyone know what's wrong now? We're already looking over our programming, but does anyone know any other probable causes?
Helen Cheng
Unread 19-11-2012, 22:17
no team (No Team)
The LEDs next to the relay port you are using on the sidecar should light up when triggered from your code. Is this occurring? If so you should focus your troubleshooting efforts on the spike. Is it powered and the PWM firmly seated in the housing? If so, your spike may be the problem.
If the LED on the sidecar does not light up, please verify that the sidecar is powered with 12V from the power distribution board. You may also want to investigate the possibility of a bad sidecar. We have had sections of this go dark before (usually as a result of poor metal shaving control). Do you have a second (working) sidecar you can swap in and try?
If none of these prompts led to a solution, could you post a couple pictures of your wiring. That way everyone can verify your connections. Good Luck.
Last edited by JohnChristensen : 20-11-2012 at 19:35. Reason: Added a couple questions
Unread 22-11-2012, 18:55
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Make sure that the relay signal used in the programming corresponds to the right Spike output (the Spike has multiple output states).
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 22-11-2012, 19:10
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
"Randomly selected"? You may have already considered this, but you have to place the PWM cable into a specific port (such as port #1), and then reference that specific port in your code as well. As others have said, LEDs will light up with different output states (as managed by your code) when the Digital Sidecar is trying to send signals to the Spike.
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 23-12-2012, 03:58
Burbelm Burbelm is offline
Burbelm is an unknown quantity at this point
We don't think the led lighting issue is because of the Spike, because it has worked before and has a good fuse in it, and all of its wire connections are secure (except for the other end of the PMW). But the Spike flashes orange/yellow in time to a clicking noise when the fuse is still in and when we turn on the robot. Any ideas about what's wrong?
You need to take help of some expert and get it placed in right place
Unread 31-12-2012, 00:31
Wildcats1378 Wildcats1378 is offline
Wildcats1378 is an unknown quantity at this point
Can't you also use one of the solenoid ports to power an LED? We haven't done so, but I was thinking about trying that.
Unread 31-12-2012, 13:19
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Can you? Yes.
Is it legal?
In 2012 2011, no...
<R60> Solenoid Breakout outputs shall be connected to pneumatic valve solenoids or photoelectric
sensors, PN 42EF-D1MNAK-A2, only. No other devices shall be connected to these
outputs.
EDIT: This rule was for 2011, as Joe says below. I pulled up the wrong year on accident.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 31-12-2012, 13:30
Originally Posted by RyanN View Post
Is it legal?
In 2012, no...
You quoted the 2011 rule. There was no such rule in 2012, which makes it legal. We'll see what 2013 brings.
Unread 31-12-2012, 14:26
RyanN's Avatar
RyanN
Oops... clicked the wrong year. You're right, 2012 does not have this rule.
I remembered this rule because we were caught doing this during inspection. We had our Triangle, Circle, Square LED indicators which we wired to the solenoid breakout. We had to rewire it using Spikes. It was the stupidest rule, but a rule is a rule, and everyone has to follow them.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 01-01-2013, 19:35
We really try to hang onto rules that make sense but never assume they will stay that way. In a few days you will know for sure.
