Go to Post Of course I'm not an admin, so this opinion is worth about as much as a disco record or AOL Free Trail CD. - PayneTrain [more]
Unread 02-01-2013, 09:46
1493kd's Avatar
1493kd 1493kd is offline
kd
FRC #1493 (FALCONS)
1493kd will become famous soon enough
2013 KB on steriods
So I think I have convienced my team that we need to go with the Kitbot on steriods. From what I have seen/heard this years kit bot will have belts instead of chain drive. I have no experience with belt drive and was wondering how this will change the setup of the KB on steriods. Does anyone have any suggestions to help us with this. Any help will be appreciated.
Unread 02-01-2013, 11:10
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Re: 2013 KB on steriods
"If your team decides to receive the 2013 KOP Drive System, you will receive an AndyMark C-Base chassis system similar to the last few years. It will again be a six wheel drive robot, with similar wheels to 2012, and with enough material to drive all six wheels. The 2013 gearbox is a ToughBox Mini with 10.71:1 reduction. The estimated final drive speed is about 10 feet per second."
The Toughbox Mini also accepts 2 CIMs so if you elect to drive each side 2 CIMS it will be very similar to the kitbot on steroids from previous years, just theoretically more efficient and lighter.
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 02-01-2013, 11:11
Feroz1325's Avatar
Feroz1325 Feroz1325 is offline
FRC #1325 (Inverse Paradox)
Feroz1325 is on a distinguished road
You can continue to use chain if you are more comfortable with it, sprockets are still on sale on Andymark and IFI (Vex Pro) so you can order your desired wheel and output sprockets once you've chosen your final gear ratio. The kit sprockets were geared too fast last year (i believe it was 26 tooth), we ended up purchasing 30 tooth ones for our 2012 competition robot.
Feroz Balsara
Team 1325 Inverse Paradox
FIRST Volunteer, College Mentor, Lead Design and Strategy Mentor!
2013 GTR West Semi-Finalists with 1241 and 2013!
2013 GTR East Champions with 1114 and 2056!
2011 GTR West Finalists with 610 and 1334!
Team1325.com
Unread 02-01-2013, 11:59
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
This year's KitBot doesn't need much to become a kitbot on steroids, right? I think all it needs is an upgrade to 4 CIM motors and a sheet of plywood to stiffen it up. I guess some people will want plaction wheels over FIRST wheels, but I like the HiGrip FIRST wheels.
Unread 02-01-2013, 12:46
Coach Norm Coach Norm is offline
Team 2468 Coach/Adviser
AKA: Norman Morgan
FRC #2468 (Team Appreciate)
Coach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond reputeCoach Norm has a reputation beyond repute
EDIT: FOund the link to the information you are referencing above.
How do you know for sure that the KOP will be the same as last year in regards to the 2013 KOP Drive System?
Was this published already?
Thanks,
Norman
FRC 2468 Team Lead 2008 - Present
Win The Day!
Unread 02-01-2013, 12:54
DampRobot's Avatar
Physics Major
AKA: Roger Romani
The main advantage of the KBoS in my mind are the AM shifters and the extra strength from the plywood. The main unknown at this point, which could determine the possibility of running a KBoS system, is the bore of the new pulleys. The output shaft on the AM shifter is 1/2" keyed, and as much as I hope that the new pulleys will be hex, this would prevent them from going in a AM shifter. I guess we'll all find out when the Kit Bot is released tomorrow.
-Plutarch
Unread 02-01-2013, 13:02
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
I think the regular kitbot isn't 6wd, but that could change this year
Research is what I’m doing when I don’t know what I’m doing.
- Wernher von Braun
Attending: Raleigh NC Regional
Unread 02-01-2013, 13:20
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Our "plan" for this season is going to be a play on the "KOP on Steroids".
Again, this will all depend on the game and our strategy, but for now, this is our plan.
Depending apon what the KOP actually contains.....
We plan on using the majority of the drive componants from the KOP, but substituting a VexPro Ball shifter with 2 CIMs per side in place of the ToughBox Mini. We will also, if possible, replicate the dimentions of the KOP drive, but build them into our own custome frame. We may even do a riff on WCD style if possible. At this point though, it will all depend on the game and what the KOP actually contains. One thing is certain though, we will be using belt drive.
Unread 02-01-2013, 13:37
Andrew Lawrence
Posts: n/a
I'm pretty sure the KBoS uses the kit CIMple Boxes, and where did you hear about the Kitbot being released tomorrow?
Unread 02-01-2013, 14:04
Ankit S.'s Avatar
Ankit S. Ankit S. is offline
FRC #2489 (The Insomniacs)
Ankit S. has a spectacular aura aboutAnkit S. has a spectacular aura about
I think they switched to Nano Toughboxes this year.
FRC 2489 - The Insomniacs
Alumnus
2489, 3189, & 701 - The Green Alliance - 2013 Sacramento Regional #6 Alliance Captain and Champions!!!
971, 254, & 2489 - 2011 CalGames Champions. Thanks 254 and 971!!!
Unread 02-01-2013, 14:12
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Where you'd expect, actually. "AndyMark Drive Base Kit...Checklist (coming 1/2/13)" [so actually today, now]. Rather odd, but there. Let's see if it happens.
Unread 02-01-2013, 14:13
From post #2
Unread 02-01-2013, 14:16
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Ok, I will volunteer the collective advice on behalf of the all the FRC participants and mentors who are face-palming while reading this post. If you have genuinely "decided" or "convinced your team" what drive chassis you will use this year before even seeing the game, your team may want to fundementally rethink your approach to this activity.
Unread 02-01-2013, 14:46
billbo911's Avatar
I agree today "should" be the date the Checklist is available, BUT, has anyone actually seen it yet?
I checked the FIRST 2013 KOP site, but nothing is there yet. And nothing on AndyMark yet either.
Unread 02-01-2013, 15:18
1493kd's Avatar
kd
FRC #1493 (FALCONS)
Why is this so? We have had sub par results in our 10 years of doing it the way that we have. We dont have enough resources to devote time to custom things and would be better served using the provided frame. The rest of the team felt that this would be a good approach. I am reaching out to the chiefdelphi community asking for advice. Before I face palm in frustration could you please explain to me how my fundementals need to be rethought?
