| Thread Tools |
Rating:
Display Modes |
Using GoPro's for robot videos
Has anyone tried using a GoPro camera for video during competition, and if so, what were your experiences using them, and what kind of shots did you take, such as views looking into robot, out of robot, diffeent angles, etc?turned on gopro,little cross came up on screen
Re: Using GoPro's for robot videos
No. Our drivers have enough to worry about driving the robot. The GoPro is pretty low priority.
I posted one on our robot a lot. Its nice to try different angles each match. I do recommend being sure the place you mount the camera is extremely strong. Just from driving around if you have your camera suspended from something that is slightly stable it will wiggle a ton. If you cant find a strong place to mount the GoPro, if you have part of the robot in the frame, it will give the viewers eyes something stationary to look at and this will help the overall viewing experience.
We used them a lot. You can check out some of the videos we used them in at our Youtube page: www.youtube.com/user/eagleforce2073
We had 3 mounting positions. One in the middle of the bot, off to one side and attached to the frame. One closer to the top, attached to the frame. And one just inside the front bumper, giving a nice view of the ball intake with a glimpse of the field. At Calgames, some teams expressed concerns over using GoPros on bots and advised us not to use ours. Apparently, a couple of teams had issues with their GoPros "frying" during matches. This never happened to us, even after use during 2 regionals and 2 offseason competitions. |
#7
Here is our GoPro footage from IRI this past summer: http://www.youtube.com/playlist?list...3XiRDGPlTHouV6
I believe it was only held on by a myriad of layers of duct tape, but it worked pretty well. If it were an official event, we would have attached it more securely. ![]() |
#8
Here is a video I threw together one day using a go pro on our robot.
http://www.youtube.com/watch?v=2YsFdmkVw4c The video itself, although you might not realize it, is from 4 different matches and 2 competitions. I do recommend finding a nice and sturdy place for it, you wouldn't want anything to happen to it. Also, make sure your memory cards are full . If you use it, try to get as many different shots as possible. It's not fun thinking of neat shot the day after your last competition... |
#9
Team 1915 used GoPro during the BattleO'Baltimore and IROC in Haymarket, VA. Worked very well at both places. Especially impressed with the amount of video you can take at 1080p with 32 GB of memory: about 6 hours. Of course, the battery only lasts about 2.5 hours, so you have to keep it charged.
We mounted it on a flat part of our frame near the flywheel, aiming forward. We used the mounting pad which came with the GoPro. The sticky tape provided with the camera attached quite well to flat aluminum angle. It is so secure (and inexpensive) that we are not even going to try to remove it. We have not posted the video from the GoPro publicly. I recommend waiting until after the game manual is released on Jan 5 before thinking too much about getting a GoPro. Once you determine if it will be legal at a competition, getting one of the early GoPros--without wifi capability. |
#10
I was given one as a gift this christmas, so I'm not worried about purchasing one. |
#11
http://www.youtube.com/watch?v=QKQ6vksrLDU
This video is my favorite frc gopro video its pretty awesome. even had gopros on the top of the minibot towers!!!! |
#12
If I'm not mistaken they require a battery, therefore they have an external power source that is not an allowed FRC power source, hence they are not legal under prior years rules during the competition season.
#13
We had two mounting points on our bot - a lower one on the ball elevator that always pointed robot forward, and one on the turret so it followed the shooting direction-- this had more vibrations when shooter wheels were spinning, but it also had the advantage that it was much closer to our LED's and the basket outlines were much brighter. For some matches in Duluth, we had two cameras on the bot, and managed to capture our most famous shot, where we launched two balls practically simultaneously from just beyond half court, and scored 3+1. During the MN State HS Robotics Tournament, we mounted a camera behind each of the the top backboards so we have a basket eye view of nearly the entire field. |
#14
It would be prudent for any team wanting to use a camera like this to double check with the event staff, such as your inspectors and/or the head ref, prior to putting it on the field. |
#15
The legality of on board cameras has been discussed here,
http://www.chiefdelphi.com/forums/sh...ghlight=go+pro |
