Go to Post If you have a problem with a team, go to that team and address it with them. Don't air your slanderous opinions here for all to see. - Andy Baker [more]
Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
  #31   Spotlight this post!
Unread 02-01-2013, 23:28
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
Re: [FTC]: NEW ROBOT DESIGNS!
Originally Posted by jcarr View Post
I like the way that your robot worked, but we ran into a problem at competition when a sister team tried a similar design and similar autonomous routine.
Your robot may have been in violation of the possession rule <GR2>. Forum entry 12 in game rules and game play seems to match your situation and seems to indicate that you should have received multiple 10-point penalties. Was there any discussion by the refs?
In our case, we had to change our autonomous and teleop so that the rings were never on the robot, despite them sliding off immediately, but of course they didn't get as close to the pegs and sometimes rolled quite far when we did not give them a ramp.
We did look into it and discuss it with the referees. They didn't have a problem with it because it always passed the "do the rings stay with the robot when you back up" test (they don't). The rings may fall down the robot or get herded en masse, but the only one in our possession is the one in the gripper.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
  #32   Spotlight this post!
Unread 03-01-2013, 10:49
jcarr jcarr is offline
Coach
FTC #3539
jcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud of
We tried the argument, but that is where the forum entry came into play, since the ring's weight is supported by the robot and moving the robot back quickly, would have the effect of moving the ring back with the robot while it is on the slide, however briefly. We just changed our approach when they said no.
I might suggest getting an official ruling on it in the forum (and be as specific as you can so that you can show it to a ref) to protect yourself, because some refs will rule it illegal and some obviously won't. You would hate to advance, then be told your robot was illegal and rack up 80 penalty points. We did not do well when we had to change our approach at the tournament.
Good luck.
  #33   Spotlight this post!
Unread 03-01-2013, 22:31
Good luck.
The FTC game manual, Section 1.5, uses the "back up" example in the definition of "possession". There is a Q&A entry about possession, and the answer just points back to section 1.5 of the game manual. Unless the rings came to a stop on robot and moved with the chassis, it doesn't meet the definition of possession. As for team 6043, our season is done. In Michigan, the only teams that make it to the Championship are the Inspire Award winners. Our alliance partner 5385 earned that award and will represent our state well.
FTC 6043 & 7911
  #34   Spotlight this post!
Unread 04-01-2013, 22:20
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
In past possession definition clarifications, if game elements would immediately separate from the robot by just its spinning motion, one way or another, this was declared an non-posession scenario.
I do agree though that an official ruling should be requested in this case, and I expect that it will be favorable.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
  #35   Spotlight this post!
Unread 06-01-2013, 16:05
Kyle_5955's Avatar
Kyle_5955 Kyle_5955 is offline
Software and Controls Mentor
FRC #5015 (SWAT Bots)
Kyle_5955 is an unknown quantity at this point
Thank you for posting all of the great robot pictures. I have really appreciated seeing all of the great ideas. My team is rookie team from Alberta, Canada, and we have tried to make a simple and effective robot that has several strategy options for tournaments. Our robot is a six wheeled slide-drive-like robot with a three segment cascading forklift that raises an arm with two joints which holds two rings and can reach all three rack heights. Our robot also has a four segment ramp which can be released to allow other robots to climb onto our robot for the end-game. We will be competing Saturday, January 12 at the Canadian Championship.
We have a video of our build season, with more of our robot coming soon, on our YouTube channel: https://www.youtube.com/user/swatbotsrobotics
