Re: Rivets: Sizes and Materials
Mostly 5/32" and 1/8", of course it depends on the materials being riveted, and where it is on the robot. Much of the stuff we do with rivets is connecting gusset plates to tubes, generally 1/16" thick. Thicker materials get bigger rivets. We seldom find a need for 3/16" rivets, and have never used 1/4" rivets. We also use a lot of #10 and 1/4" screws and bolts, mostly where stuff needs to be disassembled.
Rivets are a great fastener to use. We has some problems with 1/8" rivets last year when they were not being used in shear(design flaw). If you standardize 1/8" keep this in mind, and only use rivets for shear loads. We are standardizing 3/16" this year, because it matches up with #10 clearance, and it should hold up to much if not all the abuse you give it.
To All,
I was taught in Engineering to use a standard for any product I am going to use. Calulate the forces on a joint. At least estimated to loads both in Tension and in Shear. You will notice in this standard I picked for blind rivets that have an Aluminum body and a steel mandrel the Tensile Strength and Shear Stengths are very close to being equal. Of course as the dimameter increases the strength will increase. http://www.structural-rivets.com/Pro...fid=98&cid=105 Have fun! Proper installation is very important in any rivet application or joint. |
We prefer using aluminum mandrel rivets and designing so that the joints will mainly encounter shear loads. This makes for stronger joints. Aluminum mandrel rivets are also slightly lighter and much easier to drill out. |
