#14
creating vacuum with air cylinder
You can create a vacuum pump with the cylinder and two check valves, but those aren't allowed, right? You can perform the function of the check valves with solenoid valves--a bit of a hack but should work.
Now, is there anything in the rules to forbid you capping off the 2x4 extruded aluminum pieces and creating vacuum tanks? |
| pic: Another unsed stacker, wings down | CD47-Bot | Robot Showcase | 11 | 30-04-2003 21:36 |
| how many of u actually used the stacker if u had one? | HolyMasamune | General Forum | 21 | 14-04-2003 13:12 |
| A stacker repents... | Jason Haaga | Rules/Strategy | 24 | 03-03-2003 19:10 |
| Image Discuss: Team 753 Working on the Stacker | CD47-Bot | Robot Showcase | 2 | 22-02-2003 01:05 |
| Next Question - Check Valve | archiver | 2001 | 7 | 23-06-2002 23:18 |
