Go to Post We don't build robots because it's easy, we do it because it's hard. Maybe we can work on giving new members a warmer and gentler welcome, because it's hard ;). - Winged Globe [more]
  #31   Spotlight this post!
Unread 05-01-2013, 12:35
alectronic alectronic is offline
no team (Volunteer)
alectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant futurealectronic has a brilliant future
Re: Official Ultimate Ascent Thread!
Originally Posted by Bennetster View Post
Why are some discs colored (6 blue discs and 6 red discs 90 white disks) can you only score with your own color?
From GLOSSARY
SCORED: A DISC is considered SCORED in an ALLIANCE’S GOAL if any part of the DISC has crossed through the opening of the GOAL, is in the GOAL at the end of the MATCH, and the DISC is not in contact with any ROBOT from that ALLIANCE. Additionally, for a DISC to be considered SCORED in an ALLIANCE’S PYRAMID GOAL, it must correspond to the PYRAMID color.
  #32   Spotlight this post!
Unread 05-01-2013, 12:36
no team (Volunteer)
Originally Posted by pacoliketaco View Post
You can only score in the top pyramid goal with your own colored disks. I am not sure if you can also use them on the other goals.
Yes, you can use them as normal white disks, but then you miss out on the ALLIANCE PYRAMID GOAL points.
  #33   Spotlight this post!
Unread 05-01-2013, 12:40
Gadeer Zbedat Gadeer Zbedat is offline
FRC #1946 (Mishka Monster)
Gadeer Zbedat is an unknown quantity at this point
Awesome game )
Anyone of you can give me idea , how to climb??
(how to build the robot to climb?
  #34   Spotlight this post!
Unread 05-01-2013, 12:45
Racer26 Racer26 is offline
So after looking through the manual a few times, I haven't seen anything that would prevent the following strategy:
1. Collect 4 colored disks.
2. climb (sequentially) to the top of your pyramid
3. score disks into pyramid goal
4. retrieve falling disks from beneath goal
5. repeat steps 3&4 till the game ends
6. profit???
The pyramid goal has a floor to it, and therefore doesn't drop the disks out, also, the rule says the DISCs must be in the GOAL at the end of the MATCH to score.
However, doing so DOES turn your 30pt climb into a 50pt climb, provided you can put the DISCs in the PYRAMID GOAL with 100% accuracy.
  #35   Spotlight this post!
Unread 05-01-2013, 12:46
Jacob.B's Avatar
Happy Birthday! Jacob.B Jacob.B is offline
FRC #0068 (Truck Town Thunder)
Jacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud ofJacob.B has much to be proud of
Smile Re: Official Ultimate Ascent Thread!
And we had hoped for an easy game this year.. Oh and btw, the angle on the goals is 68 degrees, it must be a sign! Thanks FIRST gods!
2012 Championship Newton Division Finalists—Thanks 330 and 639!
2013 Kettering University District Chairman's Award Winners!
2014 Great Lakes Bay Region District Winners—Thanks 288, 4819, and 5166!
2014 Waterford District Chairman's Award Winners!
2014 Michigan FRC State Championship Chairman's Award Winners!
2015 Center Line District Chairman's Award Winners!
2015 Lansing District Winners—Thanks 314 and 1684!
2015 FIRST in Michigan District Championship Chairman's Award Winners!
  #36   Spotlight this post!
Originally Posted by Gadeer Zbedat View Post
Awesome game )
I suspect we might see a return of 2056-in-2010-esque climbing devices.
  #37   Spotlight this post!
Unread 05-01-2013, 12:48
Gabrielle3164 Gabrielle3164 is offline
FRC #3164 (Tiger Robotics)
Gabrielle3164 is an unknown quantity at this point
So we understand that you must climb the tower sequentially and you cannot touch more than two levels at once, but would that mean it is possible to remain on level 0, touch level 1 with an apparatus, then remove it and touch level two while your robot is stil on the ground and do the same for level three before lifting off of level zero? We are unclear as to whether this counts as sequentially or not.
  #38   Spotlight this post!
Unread 05-01-2013, 12:51
No. Once you remove your apparatus from level 1, you are once again touching only level 0, and so to touch level 2 would break sequential-ness. You're trying to lawyer the rule. The intent is clear, climb the tower, don't grab onto the top and pull yourself up.
  #39   Spotlight this post!
Unread 05-01-2013, 12:55
cafrava2016 cafrava2016 is offline
FRC #4063
cafrava2016 is an unknown quantity at this point
Is there any co-op points this year????
  #40   Spotlight this post!
Unread 05-01-2013, 12:56
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
No.
Team 2052- KnightKrawler
Mentor and volunteer
  #41   Spotlight this post!
Unread 05-01-2013, 13:00
Jacob.B's Avatar
I do not believe so..
  #42   Spotlight this post!
Unread 05-01-2013, 13:02
Just realized something else too. For all the hype about Kinect playing a bigger role in 2013, I don't even see anything about the Kinect at all.
  #43   Spotlight this post!
Unread 05-01-2013, 13:03
Sky Captain's Avatar
Sky Captain Sky Captain is offline
Software Mentor and FIRST Volunteer
AKA: Will
FRC #0386 (Voltage)
Sky Captain is an unknown quantity at this point
6. profit???
This is false actually, once the disc is scored it stays in the target, there is a layer of plexiglass that prevents it from falling through.
  #44   Spotlight this post!
Unread 05-01-2013, 13:13
Also, as a 2012 Field Resetter... Field Reset for this game will suck. Hard. At least frisbees don't roll like basketballs will. 130 Frisbees to sort into 6 stacks of 15, 6 stacks of 2, plus a bunch more placed on the field. Ick.
Kind of surprises me a bit, since Field Reset is a big component of the time between matches, which they've been trying to minimize.
  #45   Spotlight this post!
Unread 05-01-2013, 13:28
S2K JDM's Avatar
S2K JDM S2K JDM is offline
FRC #1378 (Hilo Viking Robotics)
S2K JDM is an unknown quantity at this point
so for hanging, could we just ride up the pipe like how some teams did in Breakaway?
Team 1378 Hilo Viking Robotics| student | 2007-2009
Team 1056 Warrior Pride| Alumni | 2009-2010
Team 1378 Hilo Viking Robotics| Mentor |2011-present
