Go to Post The real reason I am coming to IRI is to get that Paul Copioli, he will be bearhugged, if its the last thing I do :p - Mike Schroeder [more]
Unread 05-01-2013, 12:51
Racer26 Racer26 is offline
Re: Official Ultimate Ascent Thread!
Originally Posted by Gabrielle3164 View Post
So we understand that you must climb the tower sequentially and you cannot touch more than two levels at once, but would that mean it is possible to remain on level 0, touch level 1 with an apparatus, then remove it and touch level two while your robot is stil on the ground and do the same for level three before lifting off of level zero? We are unclear as to whether this counts as sequentially or not.
No. Once you remove your apparatus from level 1, you are once again touching only level 0, and so to touch level 2 would break sequential-ness. You're trying to lawyer the rule. The intent is clear, climb the tower, don't grab onto the top and pull yourself up.
