#31
Re: Official Ultimate Ascent Thread!
Yes, you can use them as normal white disks, but then you miss out on the ALLIANCE PYRAMID GOAL points.
#33
Awesome game
) Anyone of you can give me idea , how to climb?? (how to build the robot to climb? |
#34
However, doing so DOES turn your 30pt climb into a 50pt climb, provided you can put the DISCs in the PYRAMID GOAL with 100% accuracy. Last edited by Racer26 : 05-01-2013 at 13:01. |
#35
And we had hoped for an easy game this year.. Oh and btw, the angle on the goals is 68 degrees, it must be a sign! Thanks FIRST gods!
#36
I suspect we might see a return of 2056-in-2010-esque climbing devices.
#37
So we understand that you must climb the tower sequentially and you cannot touch more than two levels at once, but would that mean it is possible to remain on level 0, touch level 1 with an apparatus, then remove it and touch level two while your robot is stil on the ground and do the same for level three before lifting off of level zero? We are unclear as to whether this counts as sequentially or not.
#38
Is there any co-op points this year????
#40
#41
I do not believe so..
#42
Just realized something else too. For all the hype about Kinect playing a bigger role in 2013, I don't even see anything about the Kinect at all.
#43
#44
Also, as a 2012 Field Resetter... Field Reset for this game will suck. Hard. At least frisbees don't roll like basketballs will. 130 Frisbees to sort into 6 stacks of 15, 6 stacks of 2, plus a bunch more placed on the field. Ick.
Kind of surprises me a bit, since Field Reset is a big component of the time between matches, which they've been trying to minimize. |
#45
so for hanging, could we just ride up the pipe like how some teams did in Breakaway?
