Re: Average Winning Score Perspective
Wk1 Q: 40-50
Wk1 E: 60-80 Wk3 Q: 50-60 Wk3 E: 80-100 Wk6 Q: 50-60 Wk6: E: 100-120 C Q: 80-100 C E: 120-140. Highscore: 190. Rationale: Most #1-#2 alliances in Elims anywhere will have 2 bots that can 30pt climb. As regionals progress, more alliances will have two 30pt climbers, Wk1 Quals are weak, and one strong robot will singlehandedly win most matches, but after about Wk3, Regional Quals don't get much stronger, as the fields just aren't deep enough. Highscore rationale: Consider 1114 and 2056 (who in my estimation are virtually guaranteed to play at least one match allied this season, given that both are going to the same 3 regionals+CMP, and historically have allied as the #1 alliance all but one time that both were at the same regional). Both will be able to 30pt climb. Both will be strong Frisbee throwers that can score most of their frisbees. Assuming they score all 6 colored DISCs in the pyramid goal (30pts) plus 2x30pt climb, plus 3x6pt auto shots each is another 36pts, for 126pts, Between them, probably 2/3 of the remaining 45 discs will be scored for 3 pts. Total 216. Max score possible is (3x30pts CLIMBs) + (13x6pt Auto Mode Top Goal shots [3 robots x their initial 3, plus the 2 under the pyramid, plus the 2 closest to the ALLIANCE STATIONS]) + (6x5pt Pyramid Goal) + (45x3pt shots with the ALLIANCE STATION DISCS) + (2x3pts CENTER FIELD DISCS), assuming you don't steal any of the opposing alliance's DISCS. 339 Points, before you consider stealing DISCS, and assuming you can fit 60 discs in the Top Goal. Last edited by Racer26 : 05-01-2013 at 13:52. |
