Go to Post Next year they should make Roombas the game piece. They're not very effective at vacuuming the rug that's for sure. - Koko Ed [more]
Unread 05-01-2013, 13:29
Katie C. 3130's Avatar
Katie C. 3130 Katie C. 3130 is offline
FRC #3130 (ERRORs)
Katie C. 3130 is an unknown quantity at this point
Posession of opposing alliance disc
Is it legal for a red alliance bot to pick up or even touch a blue alliance disc (or vice versa) in order to prevent scoring on the other team? Or, could they even use the opposing team's disc to score?
Unread 05-01-2013, 13:47
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: Posession of opposing alliance disc
From what is in the manual right now, I believe it is perfectly legal to collect, horde, touch, and throw discs of the opposing alliance's color.
You cannot, however, put any discs in the opposing alliance's pyramid, as per G17:
An ALLIANCE may not put DISCS in their opponents’ PYRAMID GOAL. Violation: TECHNICAL FOUL per DISC.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 05-01-2013, 13:53
FRC #3130 (ERRORs)
Awesome! Thank you. We will continue to look for updates to the manual.
Unread 05-01-2013, 14:01
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
I feel that FIRST will create a rule update regarding this, because it dilutes the whole Pyramid Scoring theory, and if FIRST does not, my honest opinion is that teams will quickly learn how pointless Pyramid scoring is.
If you are wondering why I think that, I posted this in another thread:
The colored Frisbee are the only ones able to be used in the Pyramid Goal. There for decreasing the focus of the Pyramid Goals because there are only 12 colored Frisbee per alliance, limiting a Pyramid Goal score to 60 points, which is still a large score, but teams would need to reliably obtain the colored Frisbee and also reliably score them in the goal on top of the Pyramid. This also creates a predicament for teams that want to be able to safely just dump the Frisbee into the goal, because they would need to do that at least 3 times to get all of the Frisbee in the goal. The other thing about it is that it is hard to shoot at, and the lip and surface area of the goal is very small, making it difficult to put all of the Frisbee in there, if it is even possible!
Unread 05-01-2013, 14:06
Racer26 Racer26 is offline
As I said in the other thread, this is FALSE. There are only 6 colored DISCs per alliance.
Originally Posted by 2013 Game Manual
3.1.1 MATCH Setup
Before the start of each MATCH, the ARENA is populated with 118 White DISCS, 6 Red DISCS, and 6 Blue DISCS.
I think you're failing to consider the case of carrying the DISCs up the PYRAMID with you while you CLIMB it, and then dumping them into the GOAL. Much easier than throwing them up there.
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
There is only 6 colored discs per alliance not 12.
2012-Present Wave Robotics Team 2826
Unread 05-01-2013, 14:24
karomata's Avatar
Rebellious Egyptian
AKA: Mo Elhelw
Yes, you are correct. My bad. My point still stands though.
Unread 05-01-2013, 15:16
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
If you don't want the other alliance to take your discs, then use the feeding stations. Not that hard. I like that they're adding in some incentive to use them this year, even in the last 30 seconds when it's not necessary... of course, having said that, they'll probably change the rules this week.
Does anyone else remember when TBA signatures actually worked?
Unread 05-01-2013, 15:20
NotSoSiniSter NotSoSiniSter is offline
NotSoSiniSter is on a distinguished road
A disc is defined as any disc, regardless of the color. From how I read the rules, you can touch the other teams discs without penalty.
