Go to Post In my 30 year career, one thing I have learned is that if you truly enjoy your work, you'll be good at it. - DonRotolo [more]
Unread 05-01-2013, 14:55
Team2342's Avatar
Team2342 Team2342 is offline
None #2342
Team2342 is an unknown quantity at this point
Question about Technical Fouls
Team 2342 had a debate earlier while going over the game manual, specifically the game rules.
Rule G16 will states:
TEAMS and/or ROBOTS may not employ strategies that use DISCS to either aid or inhibit a ROBOT CLIMB.
Violation: TECHNICAL FOUL. If the DISC(S) inhibits an opponent’s CLIMB attempt, the opponent ROBOT’S ALLIANCE is awarded points for a successful Level 3 CLIMB.
Some of our team thinks that this means that if you inhibit an opponent's climb, then the opposing team will receive the technical foul points (20 pts.) AND in addition, 30 pts. the amount of a successful Level 3 climb.
The other members believe that if the climb is inhibited, the opposing team will receive 30 pts (a successful Level 3 climb) INSTEAD of the technical foul pts (20 pts.)
There is another example of this in G27.
Thank You!
Team 2342
Phoenix Robotics
