Go to Post FIRST... (is) just as human as we are. (except now in game hint season when they are big meanies) - Tetraman [more]
Unread 05-01-2013, 13:18
Grim Tuesday's Avatar
AKA: Simon Bohn
FRC #0639 (Code Red)
Climbing Up and back again
We have come upon an interesting issue with the climbing rules. It seems that nothing requires the robot remain on the tower at the end of the game--scoring is based upon reaching a level of the tower. See rule 3.1.5.2:
Points are awarded for the highest Level achieved for every ALLIANCE ROBOT that CLIMBS its PYRAMID. The Level to which a ROBOT has CLIMBED is determined by the lowest point of the ROBOT (in relation to the FIELD). CLIMB point values and Levels are defined in Figure 3-4.
Emphasis mine. Does this mean that a robot may climb up the tower at the beginning of the game, validate a climb, and have the score count at the end even if they immediately descend?
Also, from the introduction:
Teams earn additional points by CLIMBING their ALLIANCE’S PYRAMID by the end of the MATCH.
Emphasis mine. Note the by the end of the match not at the end of the match.
Another relevant rule:
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in
sequential order (Level 0, 1, 2, 3) during ascent and
no more than two (2) Levels simultaneously.
If a CLIMB is considered unacceptable (e.g. a ROBOT has touched non-adjacent Levels or more than two (2) Levels at a time), a Referee will indicate a rejected CLIMB by turning the offending ROBOT’S PLAYER STATION LED strings yellow. The ROBOT will be ineligible for CLIMB points unless and until it begins a new CLIMB from the floor, Level 0.
Assuming your climb is validated when you reach the top, must you follow the rules when descending (ie, could you go level 0,1,2,3,1,0)?
Unread 05-01-2013, 13:20
Racer26 Racer26 is offline
Re: Climbing Up and back again
My suspicion is each ROBOT can only receive points for one CLIMB in a given MATCH, and if the rules don't explicitly say so somewhere, that it will likely be fixed in a Team Update.
It wouldn't be very exciting to watch a match consisting of robots playing elevator on the pyramids.
Unread 05-01-2013, 13:26
AKA: Simon Bohn
Well they do say that the only points scored are for the highest achieved by a robot so they can't just jiggle up and down between layers for infinite points.
I have to note that the animation explicitly says that robots must remain there at the end of the game so maybe that was (very sadly) the GDC's intent.
Unread 05-01-2013, 13:33
ipburbank ipburbank is offline
President
FRC #0639 (Code Red Robotics)
ipburbank is an unknown quantity at this point
Another proposed argument against the possibility of climbing up, earning points, and climbing back down is G4:
G4 ROBOTS may only be removed from a PYRAMID under the following conditions:
A. by the TEAM,
B. unpowered,
C. and under the supervision of a FIRST Technical Advisor (FTA), FTA Assistant, Referee, or Field
Supervisor.
G4 doesn't specifically make exceptions for the robot removing itself during the match under its own power, however, I counter this argument with the following quote which implies that a robot may remove itself from the pyramid:
[...] begins a new CLIMB from the floor, Level 0
Unread 05-01-2013, 14:46
MatthewWalker MatthewWalker is offline
FRC #1448 (Parsons highschool Robotics)
MatthewWalker is an unknown quantity at this point
Definitely something they need to clarify, and quick!
Unread 05-01-2013, 14:49
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
A FAQ question, sure to be addressed in the first Team Update for sure.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 05-01-2013, 14:52
CubeNinja's Avatar
CubeNinja CubeNinja is offline
Robot Builder
AKA: Jerry Feng
FRC #0772 (Sabre Bytes)
CubeNinja is an unknown quantity at this point
From the animation: "Robots can climb up the sides or corners of the pyramid, but they have to remain there as the game ends to collect their bonuses."
Unread 05-01-2013, 15:00
IisMathwizard's Avatar
IisMathwizard IisMathwizard is offline
Programming Mentor
AKA: Mathwizard
FRC #1248 (Titanium Allies)
IisMathwizard is an unknown quantity at this point
This doesn't make sense. From the manual, however, it doesn't state this. Perhaps an update is in the future???
jRIO 2013 Project
Unread 05-01-2013, 15:13
Sam390250's Avatar
Sam390250 Sam390250 is offline
Positively Charged
FRC #0930 (Mukwonago B.E.A.R.s)
Sam390250 is a splendid one to beholdSam390250 is a splendid one to beholdSam390250 is a splendid one to beholdSam390250 is a splendid one to beholdSam390250 is a splendid one to beholdSam390250 is a splendid one to behold
Send a message via AIM to Sam390250
The rules are certainly misleading, however I am trying to understand the advantage of this... The only one I see is if you did it in autonomous mode to get it out of the way and then could focus on scoring discs the rest of the round. But depending on your method, it might waste a lot of time climbing back down safely.
If you're not intrigued, you're in trouble.
930's Harlem Shake (Only one broken leg ;] )
Unread 05-01-2013, 15:22
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
The game animation is not official and shouldn't be relied upon. here's my interpretation of why you're incorrect, but it's not absolute.
3.2.4.2: The Level to which a ROBOT has CLIMBED is determined by the lowest point of the ROBOT.
3.2.4 Final scores will be assess five seconds after the ARENA timer displays zero or when all elements come to rest, whichever event happens first.
To me, this suggests that that the climb is assessed after the end of the match. I believe the "highest Level" language is because a Level 3 climb also counts as a Level 2 climb and a Level 1 climb, not because of multiple tries. Ask the Q&A.
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
Unread 05-01-2013, 15:35
iPenguin's Avatar
iPenguin iPenguin is offline
AKA: Adam Lowe
FTC #5875 (GENIUS)
iPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant futureiPenguin has a brilliant future
Just to pull from section 1 of the game manual:
The match ends with robots attempting to climb on pyramids located near the middle of the field.
Emphasis mine.
Also:
A level 3 climb cannot count as a level 2 climb (and so on) because the level is determined by the lowest point of the robot.
2013 Season-Long Fantasy FIRST Elgin Clock Award Winner - Peach Alliance
Since 2008
2012-Present: FTC #5875, GENIUS
2008-2012: FRC & FTC #1002, The CircuitRunners
"Invention, my dear friends, is 93% perspiration, 6% electricity, 4% evaporation, and 2% butterscotch ripple."
~Gene Wilder as Willy Wonka
Unread 05-01-2013, 16:18
Rishabhgadi's Avatar
Rishabhgadi Rishabhgadi is offline
Alumni, 1255 mentor
FRC #1255 (Blarglefish)
Rishabhgadi is an unknown quantity at this point
Exclamation Re: Climbing Up and back again
So, basically you can't have a "system" attach at level two and pull you up, you have to go one at a time?
Unread 05-01-2013, 17:12
iPenguin's Avatar
AKA: Adam Lowe
FTC #5875 (GENIUS)
The way I see it, yes. You have to go from the floor (Level 0) to level 1. Then before you get to level 2, you have to get up off the floor. And before you get to level 3, you have to get off level 1.
Since 2008
Unread 05-01-2013, 17:37
mama_tree's Avatar
mama_tree mama_tree is offline
FRC #3168 (WARRIORS)
mama_tree has a spectacular aura aboutmama_tree has a spectacular aura aboutmama_tree has a spectacular aura about
Adding 2 questions to this discussion:
1. Can you use another robot to assist you in your "climb"?
2. Is your robot allowed to start inside the pyramid?
2010- Virginia Regional Rookie All Star
2010- Newton Division Highest Seeded Rookie Team
Unread 05-01-2013, 17:44
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
The manual states that a robot may support another robot only if one or both are in contact with the pyramid so, like in the animation, one robot may assist another up onto the pyramid.
There is nothing from what I hae seen that restricts where you start your climb so long as you touch the levels in the proper order.
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
