Go to Post Making a part look pretty even after it is functionaly done can be a very good thing, espically when the part gets cut from the bot and you get to keep it as a trophey. Take pride in your work. - Andy A. [more]
Unread 05-01-2013, 13:34
Tetraman's Avatar
Tetraman Tetraman is offline
FIRST on my mind
AKA: Evan Raitt
Tetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond reputeTetraman has a reputation beyond repute
Re: Climbing the Pyramid
It appears so. You have to climb one step at a time. Considering that the floor is level 0, that means you must climb onto level 1 and be completely off the ground before heading into level 2, and then completely out of level 1 before you can enter level 3.
"For every great theory about design, there is a better and contradictory theory about design. And don't let the irony of that escape you."
Unread 05-01-2013, 14:01
JHammond JHammond is offline
FRC #0811
JHammond is just really niceJHammond is just really niceJHammond is just really niceJHammond is just really nice
Re: Climbing Rules
A close rereading of the rules makes me believe this is OK:
A ROBOT Has Climbed the Pyramid if it contacts the pyramid in:
A: Sequential Order (levels 0,1,2,3)) during ascent
B: no more that 2 levels simultaneously
So even to a bot is hooking around the horizontal bar, it's only contacting the zone the bar is in, even if it it extends into the upper plane.
Unread 05-01-2013, 14:29
bolintb bolintb is offline
FRC #2435
bolintb is an unknown quantity at this point
Re: Climbing Rules
Thanks for all the clarification. I got "NOT AVAILABLE" on the Q&A site.
What about grabbing the corner post above the 30" bar? I think our robot would be in 0, 1, and 2 (i.e. on the ground, clearly in zone 1, and claw in zone 2).
WOuld this be illegal?
Unread 05-01-2013, 14:36
Norsk Norsk is offline
FRC #3662
Norsk is an unknown quantity at this point
When Can We Start Climbing
When can we start climbing the pyrimid? Is there a set time that we are suppose to climb or at any point during the round can we start our ascent?
thanks
team 3662
Unread 05-01-2013, 14:39
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Re: When Can We Start Climbing
There are no restrictions on when you can begin climbing the pyramid.
Team 2052- KnightKrawler
Mentor and volunteer
Unread 05-01-2013, 14:41
Sean M's Avatar
Sean M Sean M is offline
Alum, Mentor, and Vulonteer
AKA: Sean M. Messenger
FRC #0830 (RatPack)
Sean M is an unknown quantity at this point
Agreed, there are no restrictions on contacting your own pyramid.
Sean M. Messenger
Mentor: FRC Team 830
Alum: FRC Team 2046
Unread 05-01-2013, 14:45
mega900997's Avatar
mega900997 mega900997 is offline
FRC #0263 (Sachem Aftershock)
mega900997 is on a distinguished road
Climbing Time
Does anyone know when you can start climbing the pyramid during the match?
Suffield Shakedown Winners & Most Points Scored
South Florida Regional 6th Seed, #5 Alliance Captains, Regional Winners w/ 2383 & 386, Innovation in Control Award
NY Tech Valley Regional 5th Seed, QF, Excellence in Engineering Award
SBPLI Long Island Regional 4th Seed, Finalists
Hopper Division 14th Seed, QF
Unread 05-01-2013, 14:48
Bluelightning's Avatar
Bluelightning Bluelightning is offline
AKA: David
FRC #3157 (Eastridge Robotics)
Bluelightning is an unknown quantity at this point
Re: Climbing Time
I also am curious about this. Can we climb at any time, or just during the endgame?
Eastridge Robotics Rule!
Unread 05-01-2013, 15:15
MatthewWalker MatthewWalker is offline
FRC #1448 (Parsons highschool Robotics)
MatthewWalker is an unknown quantity at this point
Clarification of tower zones
My team is having some trouble understanding how climbing the tower works with regards to zones . could someone please clarify for us?
Unread 05-01-2013, 15:27
Sean M's Avatar
FRC #0830 (RatPack)
Re: Clarification of tower zones
The zones are explained in section 3.2.4.2 such that level 0 is on the ground, level 1 is above the ground and below the first bar, level 2 is between the first and second bars, and level 3 is above the second bar. The lowest point on your robot as it is hanging is what will be used to determine the level -- and parts A and B of 3.2.4.2 specify what validates a "CLIMB."
 [G22] Robots must contact the pyramid in
A. sequential order (Level 0, 1, 2, 3) during ascent and
B. no more than two (2) Levels simultaneously.
The paragraph at the end means that you cannot skip up bars. So you can climb from the first bar to second bar and hang in level 1 for 10 points, but if you go from the ground to the second bar still in level 1 zone you get no points (invalidated climb) because you didn't climb in sequential order.
Does that help?
Sean M. Messenger
Alum: FRC Team 2046
Unread 05-01-2013, 15:41
thank you very much!
Unread 05-01-2013, 15:49
brndn's Avatar
brndn brndn is offline
AKA: Brandon
brndn is just really nicebrndn is just really nicebrndn is just really nicebrndn is just really nicebrndn is just really nice
Also note that the levels include the width of the bar above them, shown in the field tour video and figure 3-4 in section 3.1.5.2 of the game manual.
http://www.youtube.com/watch?feature...tMJA4g#t=36 s
Unread 05-01-2013, 15:56
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Climbing Rules
They commonly don't open the site for a couple days, so as to avoid posting of stupid questions that can be answered with a second read of the manual. Not that this thread is stupid - I'm sure there will be plenty of clarifications on the scoring zones, the ladder 0-1-2-3 rule, etc.
Would this be illegal?
Problems. You've got 2 possibilities here:
1. Touching zone 0 (floor) and zone 2 (corner bar above the 30" bar) but not touching zone 1 - illegal because you skipped a zone.
2. Touching all 3 (0, 1 and 2) - illegal because you can only touch 2 zones at a time.
(since 2004)
Unread 05-01-2013, 16:06
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Climbing Rules
Originally Posted by JHammond View Post
Imagine a robot that placed a pair of hooks over the bar @ 30", while the robot is on the ground.
Is the robot in zones 0,1, and 2 and therefore executing an illegal climb?
Here's my interpretation of the rule, which states:
Originally Posted by 3.1.5.2 CLIMB Points
A ROBOT has CLIMBED its PYRAMID if it contacts the PYRAMID in
The key point is contacting the pyramid. If you grab onto the bottom rung, you are touching level 0 (the floor) and the pyramid in level 1. However, you are not touching the pyramid in level 2, and so it is okay.
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Climbing Rules
Several threads of similar subject merged into one.
(since 2004)
