Go to Post Take it from a team that mastered tank treads and still hasn't built them in over a decade - it's not worth it. - Isaac501 [more]
  #31   Spotlight this post!
Unread 05-01-2013, 16:07
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Re: Climbing Rules
Originally Posted by JHammond View Post
A close rereading of the rules makes me believe this is OK:
A ROBOT Has Climbed the Pyramid if it contacts the pyramid in:
A: Sequential Order (levels 0,1,2,3)) during ascent
B: no more that 2 levels simultaneously
So even to a bot is hooking around the horizontal bar, it's only contacting the zone the bar is in, even if it it extends into the upper plane.
This is the key here. The way the rules are written it explicitly mentions "contacts", which means that the robot must physically touch the pyramid within that level to be considered in it (I don't see how projecting into the plane can be considered contacting).
This does make climbing the corners of the pyramid a more hazardous proposal, since it's fairly easy to contact a tiny portion of the pyramid just barely in level 2 while still contacting level 0 at the corners.
  #32   Spotlight this post!
Unread 05-01-2013, 16:10
mikemascot's Avatar
mikemascot mikemascot is offline
SIR MASCOT
AKA: Mike handte
FRC #0316 (LuNaTeCs)
Team Role: Mascot
mikemascot is an unknown quantity at this point
Re: Climbing Rules
how many robots can the pyramid hold at its max tolerance
  #33   Spotlight this post!
Unread 05-01-2013, 16:20
Dominator1619's Avatar
Dominator1619 Dominator1619 is offline
FRC #0313 (Bionic Zebras)
Dominator1619 is an unknown quantity at this point
Re: Climbing Rules
Has anybody seen anything in the rules about climbing the corner bars as opposed to the horizontal bars?
So where is this cake I was promised?
  #34   Spotlight this post!
Unread 05-01-2013, 16:23
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Climbing Rules
No prohibition, but the kickoff did direct you to consider the way the horizontal bars and the corners intersect.
(since 2004)
  #35   Spotlight this post!
Unread 05-01-2013, 16:25
Sean M's Avatar
Sean M Sean M is offline
Alum, Mentor, and Vulonteer
AKA: Sean M. Messenger
FRC #0830 (RatPack)
Sean M is an unknown quantity at this point
Re: Climbing Rules
I would lend emphasis to the "contact" part of 3.2.4.2 rather than being in the zones themselves. As JHammond mentioned, any robot taller than 30" would otherwise immediately violate the rule (touching level 0, in zone 1 and zone 2). My interpretation is that the only thing being restricted is CONTACT with the pyramid, not presence in a zone.
Another thing to consider the legality of would be the scenario of lifting an alliance robot. Per the rules, your robot could have climbed in the traditional sense (whatever that may be), be in Level 3, and then lift an alliance mate (say by hooking on some point on their robot) by [G33] through to Level 2. This alliance robot would have contacted the pyramid in sequential order (only Level 0) and satisfies restraint B.
Sean M. Messenger
Mentor: FRC Team 830
Alum: FRC Team 2046
  #36   Spotlight this post!
Unread 05-01-2013, 16:34
Team1339 Team1339 is offline
FRC #1339
Team1339 is an unknown quantity at this point
Re: Climbing the Pyramid
Originally Posted by Spartechs2441 View Post
Regarding the pyramid
Does this mean that you cannot hook onto the 2nd bar, then climb up and touch the 1st bar on the way? You have to hook up to the 1st, then 2nd, and finally 3rd bar while only touching the next level?
This could mean that the robot can't be in contact with more than 2 zones of the pyramid at the end of the match, couldnt it?
  #37   Spotlight this post!
Unread 05-01-2013, 17:33
MisterG's Avatar
MisterG MisterG is offline
Think twice post once.
AKA: Alan Gilgenbach
FRC #2062 (C.O.R.E. - Community of Robotics Engineers)
Team Role: Team Spirit / Cheering
MisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to allMisterG is a name known to all
Re: Climbing Rules
We have been discussing this clause in section 3.2.4.2:
Points are awarded for the highest Level achieved for every ALLIANCE ROBOT that CLIMBS its PYRAMID. The Level to which a ROBOT has CLIMBED is determined by the lowest point of the ROBOT (in relation to the FIELD).
We can't agree on whether this means that a robot score points by climbing early and descending.
That is are points only awarded for robots that are in position when the game time expires.
Our early interpretation is that the points will be awarded no matter when the climb happens but this is certainly a point for the official Q&A.
Al G.
Alan Gilgenbach
C.O.R.E 2062
  #38   Spotlight this post!
Unread 05-01-2013, 18:09
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: Climbing Rules
My interpretation is:
The Pyramid is described in section 2.2.5, and is composed of the steel tubing (et al), and the 4 steel bases (24 inch square). Except for the steel plates, the Pyramid does not include the floor under the pyramid.
Separately, there are zones designated as levels (0 through 3). Parts of the Pyramid are in each Zone. But, the Zones are not the Pyramid.
Section 3.1.5.2. CLIMB Points. The Robot has climbed the Pyramid if it contacts the pyramid in no more than two levels simultaneously.
There is no rule that restricts how many zones your bot can simultaneously occupy. Only how many points of contact you can have with the Pyramid.
Only the steel plates of the Pyramid are in level 0.
The first bar is in level 1.
The second bar is in level 2.
So, it is possible to hook onto the 2nd bar, and not violate the rule, if you are not touching a steel plate. This makes it easy to clear the floor (level 0) using the 2nd bar.
Note: make sure you comply with the sequential order rule. Contact the pyramid in level 1 before you contact the 2nd bar. Nothing I see requires you to do anything with the 1st bar. Note 2: The sequential rule does reference level 0, so maybe make sure to touch the steel plate (only part of the pyramid in level 0) before you touch anything else.
You can reach above the 2nd bar, into level 3, as long as you do not touch any part of the Pyramid in Level 3 (the 2nd bar is fully in level 2).
In order to touch the 3rd bar, or any vertical piece above the 2nd bar, you cannot be touching any part of the Pyramid at or below the 1st bar, or you would violate the rule (this presumes you are touching the 2nd bar).
In summary, being "in a zone" does not cause problems. Touching the pyramid in more than 2 zones at a time, does cause problems.
Getting off level 0 is not that difficult (first 10 points). The difficult part is clearing the first bar while only holding onto the 2nd bar (second 10 points) and not touching any part of the pyramid at or below the 1st bar (hanging below, but not touching is ok). Once you have reached that point, then you can touch the 3rd bar, and then clear level 2 (third 10 points).
Note: This is a strict reading of the rules. Future clarifications may affect the interpretation. Such as, a clarification that the floor under the Pyramid is considered part of the pyramid for "contact" purposes, and the floor is considered in level 0. That would mean you have to clear the floor before you can touch the 2nd bar.
  #39   Spotlight this post!
Unread 05-01-2013, 21:16
indubitably's Avatar
indubitably indubitably is online now
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
I think this is what really needs the clarification. I believe you will still have to obey that rule while climbing after the clarification, but right now, I don't think it's 100% clear. That would make it way easier to climb.
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
  #40   Spotlight this post!
Unread 05-01-2013, 21:28
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Re: Climbing Rules
Al G.
What is your interpretation of G4 ?
"3.2.1.4 G04
ROBOTS may only be removed from a PYRAMID under the following conditions:
A. by the TEAM,
B. unpowered,
C. and under the supervision of a FIRST Technical Advisor (FTA), FTA Assistant, Referee, or Field Supervisor.
Additionally, if any part of the ROBOT is in Level 3, TEAMS are required to attach a FIRST supplied belay line, detailed
in Section 2.2.6, to their ROBOT to spot a ROBOT while the TEAM removes it from the PYRAMID."
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
  #41   Spotlight this post!
Unread 05-01-2013, 22:21
jason701802's Avatar
jason701802 jason701802 is offline
FRC #0753 (The High Desert Droids)
jason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant futurejason701802 has a brilliant future
Re: Climbing Rules
A. sequential order (Level 0, 1, 2, 3) during ascent and
It certainly references level 0
Jason
  #42   Spotlight this post!
Unread 05-01-2013, 22:39
ddesportes ddesportes is offline
Team Ursa Major Lead Tech Mentor
AKA: David DesPortes
FRC #2849 (Ursa Major)
ddesportes is an unknown quantity at this point
Re: Climbing In 3 Sections
We have the same conundrum with climbing through level 2. If the robot grips the bar at the top of level 2, presumably part of the gripper is over top of the bar and, therefore, in Level 3. If at the same time the robot still has some attachment to the bar at the top of Level 1, the robot would be in three levels at once. I sincerely hope this is not the intent of the rules.
  #43   Spotlight this post!
Unread 05-01-2013, 22:52
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
[G22] Robots must contact the pyramid in
B. no more than two (2) Levels simultaneously.
Emphasis mine.
This rule reads a little funny at first, but when you take it for exactly what it says, I think it becomes clear. There is nothing about how many zones the robot can occupy, but how many different zones the robot may contact. This is why the planes for the zones are above the horizontal members.
Let's say you are going to score on the second level (20 points). Your first step, following G22, would be to move from level 0 (the ground) to level 1(fully supported by the section of the pyramid in zone 1). You are now free to move on from the section of the pyramid in zone 1 to the section in zone 2.
I hope this is a helpful explanation.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
  #44   Spotlight this post!
Unread 05-01-2013, 22:59
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Originally Posted by Redo91 View Post
Emphasis mine.
So...does this make scaling corners as difficult as I think it does?
  #45   Spotlight this post!
Unread 05-01-2013, 23:02
Redo91's Avatar
AKA: Justin
Only as difficult as you design it to be.
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
