Go to Post On a team, saying "it's not my job" is simply not acceptable. - dlavery [more]
Unread 26-12-2012, 12:07
Michael_Lee Michael_Lee is offline
FRC #2976
Michael_Lee is an unknown quantity at this point
Using WindRiver from the command line?
Is there some way of compiling and deploying code from the command line? Our non-programming teammates want to be able to deploy and use code if none of our programmers are present. I've showed several of them how to do it from WindRiver/wrote step-by-step instructions, but I'm looking for a way to simplify the process.
I'm fairly certain deploying the code is just a matter of using ftp to transfer the compiled file to the cRio. Which folder should I place the compiled file in?
Unread 26-12-2012, 20:12
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Re: Using WindRiver from the command line?
I'm not sure about windriver, but with java, there's several other things that are sent to the robot such as a manifest file which tells the robot what code to run when it starts up.
Unread 26-12-2012, 22:08
FRC #2976
I think I figured out at least the first part. Assuming that your WindRiver install is located at C:\WindRiver and your project is located in C:\WindRiver\workspace\SimpleTemplate, you need to...
  1. Add the following to your path (to compile, you need to use gnu make, bash, and other assorted linux console utilities. The following directories contains Windows versions of those)
    • C:\WindRiver\gnu\3.4.4-vxworks-6.3\x86-win32\bin
    • C:\WindRiver\utilities-1.0\x86-win32\bin
    • C:\WindRiver\setup\x86-win32\bin
  2. cd to C:\WindRiver\workspace\SimpleTemplate\PPC603gnu
  3. Type
    set WIND_BASE=C:\WindRiver\vxworks-6.3
  4. Run the following command:
    make --no-print-directory BUILD_SPEC=PPC603gnu DEBUG_MODE=1 TRACE=1
I'm still uncertain about the second part though.
Unread 05-01-2013, 16:35
rbmj rbmj is offline
FRC #0612 (Chantilly Robotics)
rbmj is a jewel in the roughrbmj is a jewel in the roughrbmj is a jewel in the rough
Deploying the code is just a matter of (from ucpp)
wput -u $CPP_PROJECT_NAME/Debug/$CPP_PROJECT_NAME.out ftp://anonymous@$DEPLOY_IP/ni-rt/system/FRC_UserProgram.out
Or the moral equivalent (where wput -u is copy over ftp)
