Go to Post FIRST is here to reach the affluent, already college-bound students with boundless resources; it is also here to reach the poverty-stricken urban and rural students who don't see a diploma as worthwhile, and everybody in between. - Taylor [more]
Unread 05-01-2013, 17:11
ABA's Avatar
ABA ABA is offline
FRC #1153
ABA is an unknown quantity at this point
pyramid rectangle size
does anyone have the dimensions for the rectngular dimensions of each level, i know the top one, but the other two are very difficult to decipher in the field drawings?
Unread 05-01-2013, 17:18
karomata's Avatar
karomata karomata is offline
Rebellious Egyptian
AKA: Mo Elhelw
karomata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud ofkaromata has much to be proud of
Re: pyramid rectangle size
Through rough calculations our team has found that the top square rungs of the pyramid will create a 30x30 inch square. We have not discussed the middle set of rungs though.
EricDrost's Avatar
EricDrost EricDrost is offline
Eleven to MidKnight
FRC #1923 (The MidKnight Inventors)
EricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond reputeEricDrost has a reputation beyond repute
Trying to figure out the same thing right now. I'll post them as I go.
EDIT:
Top: 25.25 x 25.25 from centerline to centerline of the tubes.
Middle: 49.13 x 49.13 centerline to centerline.
Bottom: 73.63 x 73.63 centerline to centerline.
EDIT: I'm not sure if these are exactly right, it's hard to tell if the dimensions for the base are for the centerline, inner or outer.
MORT Team 11: 2008 - 2015
MKI Team 1923: 2015 - Present
Unread 05-01-2013, 17:22
BrendanRadabaug's Avatar
BrendanRadabaug BrendanRadabaug is offline
FRC #1902 (Exploding Bacon)
BrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to beholdBrendanRadabaug is a splendid one to behold
check out the first couple pages of the [2013 Team Drawings] look at the length of each segment, make a square.
bottom is 73.02 long pipes
middle is 48.57 long pipes
top is 24.25 long pipes
Bacon
Unread 05-01-2013, 17:34
ABA's Avatar
ABA ABA is offline
FRC #1153
thank you very much
