Go to Post If your logo is your team number in a font 4" tall in 1/2" stroke, colored/outlined in white, then yes. Otherwise, no. - cadandcookies [more]
Unread 05-01-2013, 18:56
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Re: Circular/cornerless robot - Bumper free or fully bumpered?
I think that Jon is on the right track. With an infinite number of exterior corners, and a bumper that completely surrounds the circular robot, it would be impossible for an inspector to state the the rule is not satisfied. An inspector would not be able to determine where one starts and the other ends. Backing into the description, if the bumper surrounds the robot it must be completely protecting the frame perimeter regardless of corners.
I am a little confused. So you are saying a completely round robot surrounded completely with a bumper would satisfy the rules? What about the numbering? I suppose just put at 90 degrees and call it good.
The other question is how to make a completely round bumper out of 3/4" wood material.
-T
Unread 05-01-2013, 19:42
GaryVoshol's Avatar
Cogito ergo arbitro
Steam box.
Going back to a non-circular robot, if one of your edges between corners is less than 8", you're out of luck. You can't protect 8" on either side of a corner of the adjacent edge is < 8".
(since 2004)
Unread 05-01-2013, 19:47
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Building on that -- since the perimeter cannot exceed 112", a polygonal frame perimeter cannot have more that 112/8 = 14 sides. So a frame perimeter with, say, one million sides would be illegal -- and indistinguishable from a circle. Hmm, maybe the circular frame perimeter is illegal after all?
Richard Wallace
since 2003
Unread 05-01-2013, 19:59
JJackson's Avatar
JJackson JJackson is offline
FRC #0781 (Kinetic Knights)
Team Role: Driver
JJackson is an unknown quantity at this point
You could laminate your own plywood into a circle. You would also have to make a jig to hold it as the glue dries
Unread 05-01-2013, 21:05
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
You could steam the plywood & make a circle.
But R2 describes the frame as a polygon. It is stretching the definition of a circle to call it a polygon.
R22 requires 8" of bumper between each outside corner of a polygon. Even if you buy into a circle being a polygon, there is not 8' between outside corners.
R29A Requires the bumpers be supported by the frame 1" from each end the bumper. How can you do this if the bumpers have no end?
Not being a inspector or on the rules committee, my opinion is not the one you have to use.
Anybody notice that R22 exempts the bumpers from bag & Tag?
Unread 05-01-2013, 22:35
Isn't anyone going to talk about the need to have a continuous backing board to prevent someone from determining a start and end to the bumper? Or getting the bumper to weigh less than 20 lbs? Boy you guys try to make my job harder every year.
Unread 05-01-2013, 22:39
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by Richard Wallace View Post
I think Brandon's right.^
So, assuming it must have bumpers, would a circular frame with <112 inch perimeter (i.e., <35.6" diameter) offer any advantage for Ultimate Ascent?
You could roll it sideways instead of using a robot cart?
I think a circular bumper would pass inspection. I would pass it, as an inspector. Al S (THE Lead Robot Inspector) says so too.
To make such a bumper, make your own plywood. 1/16" strips of wood, steamed, glued and clamped will make a plywood circle. Ever see a bent-wood chair?
Leav, if you build that please post a photo! That would look awesome!
Unread 05-01-2013, 22:45
AdamHeard's Avatar
Lead Mentor
With access to a moderate sized wood router, teams could also cut hoops then stack and glue them vertically.
Unread 08-01-2013, 16:02
NanoCollins's Avatar
NanoCollins NanoCollins is offline
FRC #1706
NanoCollins is an unknown quantity at this point
Didn't a team make a circular robot a few years ago... for like Lunacy or something?
Unread 08-01-2013, 17:13
Dragonking's Avatar
Dragonking Dragonking is offline
AKA: Aaron Cannon
Dragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really niceDragonking is just really nice
make a circular robot with a square bumper surrounding it
Unread 05-01-2013, 23:59
Leav's Avatar
Leav Leav is offline
Spud Gun Division
AKA: Leav Oz-Ari
FRC #3316 (D-Bug)
Leav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond reputeLeav has a reputation beyond repute
Send a message via ICQ to Leav Send a message via AIM to Leav Send a message via MSN to Leav
Nice!
Oh... I think i'll be focusing on actually throwing discs and climbing the pyramid... no time to muck about with a circular robot!
"We choose to build robots this season and do the other things; Not because they are easy, but because they are hard."
-Paraphrasing JFK
Participated in FIRST as a student: 2005-2006 (But still learning every season!)
Mentor: 2008 - ? (Team 2630 2008-2011, and Team 3316 since 2013)
Engineer: 2011 - ? (B.Sc. and M.Sc. in Mech. Eng. from the Technion IIT)
FIRST Volunteer - 2007 - ? (MC, FTA, FIRST Aid etc.)
Unread 07-01-2013, 02:38
nathannfm's Avatar
nathannfm nathannfm is offline
AKA: Nathan
FRC #3940
nathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant futurenathannfm has a brilliant future
What's everyone think about an oval or football/lemon shaped frame perimeter, with pointy ends, the points are clearly "outside corners" so we would need bumpers on them, but what about the rest, of it?...or any convex frame...has this never come up before?
[2016-20??]: Mentor: FRC Team 3940"CyberTooth"
[2013-2016]: Mentor: FRC Team 365 "MOE"
[2012-2013]: Mentor: FRC Team 3929 "Atomic Dragons"
[2011-2012]: Mentor: FRC Team 365 "MOE"
[2008-2011]: Student: FRC Team 365 "MOE"
[2007-2008]: Student: FTC Team 365 "MOE"
[2005-2007]: Student: FLL Team "The MOEstangs"
Unread 07-01-2013, 03:04
DampRobot's Avatar
Physics Major
AKA: Roger Romani
I really like how this thread has turned into a serious discussion of the benefits of circular robots, and features some of the best CD members. Let's take this discussion one step farther: what about a spherical robot?
As a robot inspector, I would read the rules as such. The frame perimeter is defined as a polygon. A polygon has corners. So the corners would have to be covered (to 8") with bumpers. So the robot would need to be encompassed by bumpers.
-Plutarch
Unread 07-01-2013, 03:25
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Not necessarily. The frame perimeter in the contact zone needs to be covered in bumpers. The rules never specify bumpers above the contact zone. In fact, the robot cannot exceed the frame perimeter (at the contact zone, thus the bumper perimeter) in starting configuration, so a spherical robot is impossible.
A circular robot on the other hand would be confounding. However, let's assume for a moment that the robot is perfectly circular (practically, it never could be). Thus, there would exist either no corners, or an infinite number of corners. Now, a strict interpretation of the rules indicates that each corner must have at least 8" of bumper on either side not that each side be at least 8 inches. Thus, if a circle were to consist of all corners, then the entire frame perimeter would need to be covered with bumpers. If it were not, then no bumpers!
However, we know we can't make a perfect circle. We'll have to make it an infinitesimal n-gon, or as near that as possible. Thus, we define it to be infinite corners, thus the robot needs bumpers on all sides. Practically, though, it'd probably be a single U-channel bent and welded or bolted at one spot to itself to close the circle. So if you could bend it nicely, then it'd actually be a teardrop, so you'd only need a 16" bumper near the weld!
To be honest, the rules, especially in previous years, have had disclaimers stating that the intent of the rule, not the word of the rule, will be enforced. I believe the intent of the rule here is to prevent injury and damage to a robot or human should a corner come in contact with something. A 90 degree corner will normally rip stuff, if there's no covering on it. A round bot won't run corners into anything, it'll just rub. I don't think bumpers were intended to protect much against head-on collisions - it wouldn't help with holes in the bumpers (as the rules currently allow), so I think that the inspectors wouldn't consider that. Likewise, the GDC probably wouldn't have thought this discussion possible, or if they did, they probably (and rightly so) guessed it to be purely theoretical.
Sorry about the rant. I think I got my point through though.
Unread 08-01-2013, 00:03
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Every year we're told to not lawyer the rules. In every previous FRC year, to my knowledge, circular have A. been legal and B. completely surrounded by bumpers.
Lets not over complicate things
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
