Go to Post Building a 'bot is kinda like washing your hair, but instead of "rinse, lather, repeat"... you should "engineer, test, repeat". - Andy Baker [more]
Unread 05-01-2013, 19:43
elsenor elsenor is offline
FRC #2134 (AzTecs)
elsenor is an unknown quantity at this point
Ideas for shooter
Our team has come up with an initial design for our frisbee shooter (we're yet to come up with a device to pick up the frisbees). It's similar to the shooter in this video: http://www.youtube.com/watch?v=bRBg-...u8SDSA&index=1
What do you guys think of this? What is your team planning to do in terms of strategy? Are you going to aim for the highest rack or are you trying to nail as many frisbees as you can into the lower and middle slots? Are you going to shoot the frisbee or just put it through the slot with a manipulator? Good luck everyone!
Better Question: What isn't my main role on my team? O.o
Unread 05-01-2013, 19:56
flamer075 flamer075 is offline
FRC #3200
flamer075 is an unknown quantity at this point
Re: Ideas for shooter
I have thought of the same idea. What do you guys plan on doing to climb the pyramid? And picking up frisbees from the ground. Does any one have any blueprints that they could show us?
Unread 05-01-2013, 20:40
FRC #2134 (AzTecs)
We haven't thought about climbing the pyramid that much yet. But for picking up the frisbee my idea is to have two wheels rotating inwards and then we drive over the frisbees to pick them up. Another idea is to have a metal plate tilted towards the ground and we go to a frisbee, tilt the plate a little after some of the frisbee is on the plate.
Unread 05-01-2013, 20:46
FRC #3200
Won't the frisbee tilt, and what happens if the frisbee is upside down or slanted against a wall?
Unread 05-01-2013, 20:55
ProgrammerTori's Avatar
ProgrammerTori ProgrammerTori is offline
It's always a programming error.
AKA: Victoria Vanderbach
FRC #2068 (Team 2068 - The Metal Jackets)
ProgrammerTori is on a distinguished road
There will probably be lots of missed frisbees on the ground. I think a speedy bot with capabilities to pick up missed frisbees and dump them in a low goal could prove useful. I suggest looking at old overdrive designs to maximize maneuverability for low scoring robots. And maybe incorporate a basic hanging device for an additional 10 points.
Unread 05-01-2013, 20:58
FRC #2134 (AzTecs)
That's another idea that we have up for consideration. I'd say we can get 80+ percent of the bees into the low hoops. But...there's just something exciting about getting a robot to shoot. You know what I mean right?
Unread 05-01-2013, 21:04
I agree. But a robot hanging 10' off the ground with a sticker on the bottom that says "if you can read this, we just scored 30 points" would be pretty awesome as well.
Unread 05-01-2013, 21:21
RoboLee1629 RoboLee1629 is offline
FRC #1629
RoboLee1629 is an unknown quantity at this point
My teams stratagy for shooting is the middle goal. Much like the middle hoop in last years game, the middle goal is a small distance from what the height of the robot can be (it is just over 4 inches) so far, one of the ideas is to shoot at that goal quickly from very close to the wall.
Unread 05-01-2013, 21:22
ABA's Avatar
ABA ABA is offline
FRC #1153
ABA is an unknown quantity at this point
anyone know how big of an effect there is if the frisbee is thrown upside down, or any ways people are planning on flipping them?
Unread 05-01-2013, 21:25
FRC #2134 (AzTecs)
We tested out if we can throw the bee upside down, but found that the bee curves a lot and experiences a lot of drag this way. The only way to counter this is to put absolutely no spin on the bee, which is pretty hard.
Unread 05-01-2013, 21:27
ABA's Avatar
ABA ABA is offline
FRC #1153
ok thanks
Unread 05-01-2013, 21:28
FRC #2134 (AzTecs)
Also do you mind if our team uses this idea here at the AZ Regionals?
Unread 05-01-2013, 22:20
Dr. Poptart's Avatar
Dr. Poptart Dr. Poptart is offline
AKA: Ysidro Perez
FRC #1817 (LLano Estacado RoboRaiders)
Dr. Poptart is an unknown quantity at this point
My team had the idea of doing a sort of rail gun design if you can call it that. We have a vague idea of how we're going to go about it. We're deciding on whether to go pneumatic or use wheels like a pitching machine which we did for Rebound Rumble. This will obviously be more guided since it is a frisbee we're shooting, hence the rails. Just wanted to put my idea out here. This is my second year in FIRST and my team's fourth year so we'd like to help as much as we can even if it's just a small amount we can give.
Unread 05-01-2013, 22:22
DonRotolo's Avatar
Back to humble
FRC #0832
I am thinking of the same basic idea. But instead of a hard wheel and curve, I am considering something with more give, like 1/2" closed-cell foam for the curve and something softer on the wheel, like waffle tread.
Unread 05-01-2013, 22:25
knuckleduster knuckleduster is offline
AKA: Jack Manning
FRC #0058 (The Riot Crew)
knuckleduster is an unknown quantity at this point
The only problem with shooting for the bottom goal is that you have a limited ammount of frisbees to score in a match. There are only 51 ish per team plus the ones on the field at the start, that is not a lot of attempts to get a high score, and if you take all of your 45 and score one than the other team only has to score 1/3 or 1/2 of that to tie you.
*edit*
Tonight we built a prototype shooter and had fantastic results!
http://www.youtube.com/watch?v=LD9Ic_rBRmk
Theres a video
Last edited by knuckleduster : 06-01-2013 at 20:28. Reason: Additional Information
