Go to Post One last thing, if a mechanical part fails on you, sometimes you can get a little bit of noise back into it by yelling at it, kicking it, or pounding on it with your fist. This might put enough back into it so it will work for a few more minutes. - KenWittlief [more]
Unread 05-01-2013, 21:50
thecakeisalie's Avatar
thecakeisalie thecakeisalie is offline
FRC #0293
thecakeisalie is an unknown quantity at this point
Question about vision processing rules
So I was browsing the Kit of Parts this year, and noticed a copy of RoboRealm which we might use to do vision processing this year.
However, I took a look at the FRC manual which states that:
The Driver Station software provided on the Kit of Parts website is the only application permitted to specify and communicate the operating mode (i.e. Autonomous/Teleop) and operating state (Enable/Disable) to the ROBOT.
Does this mean that RoboRealm would need to be installed on a netbook strapped onto the robot or is it legal to install it on the driver station?
Unread 05-01-2013, 21:55
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Re: Question about vision processing rules
It means the Driver is the only program to specify operating mode to the robot.
Nothing to do with vision processing as long as you don't mess with enabling/disabling the robot through vision processing.
Smart dash board is another program that can read & set variables to the robot for example.
