Go to Post A chop saw may cut aluminum, a knife can also be used to eat ice cream. - fox46 [more]
Unread 05-01-2013, 21:30
Joon Park's Avatar
Joon Park Joon Park is offline
Joony13
FRC #0639 (Code Red Robotics)
Team Role: CAD
Joon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud ofJoon Park has much to be proud of
Re: UpsideDown Frisbees
Another ultimate player here, completely agree with what ehfeinberg has been saying. Because ultimate is played more by the robotics population than basketball we'll see more "hail mary"s make it into the goals, but not much more. I wouldn't count on it being something you see every game; far from it, in fact.
Also, the 5 point goal is very misleading if you've ever played disc golf. In disc golf, if you hit the pole with the chains, you're pretty much guaranteed that it will fall in the goal. Here, that is not the case because of the different dimensions and the fact that a robot will be throwing them.
Team 639: Code Red Robotics
2013 Robot: The Red Raptor
2013 Archimedes Division
2013 Buckeye Regional Winner
2013 Buckeye Spirit Award
2013 FLR Spirit Award
2012 Newton Division Finalist
2012 FLR Semi-Finalist, Engineering Inspiration Award
2012 DC Quarter-Finalist, Industrial Design Award
2011 FLR Quarter-Finalist
2011 Boston Quarter-Finalist, Imagery Award
2010 FLR Quarter-Finalist, Innovation in Control Award
2010 Philladelphia Semi-Finalist, Gracious Professionalism Award
Unread 05-01-2013, 22:17
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by tj1673 View Post
from playing Ultimate Frisbee, I can say that frisbees do NOT fly well upside down (unless you bomb them, which is terribly inaccurate and has poor consistency). Now, I'm not sure how well they would work out of a shooter, but I imagine that even with a consistent machine, they won't fly well upside down.
Originally Posted by ehfeinberg View Post
Being an Ultimate Player, I can say that disc's do fly differently if they are upside down. When a disc is upside down, it tends to not fly as far and floats more. Also, a Frisbee thrown upside down tends to wobble to either side.
Ah, but what it you want to throw them only about 15 feet? Are the trajectories similar enough (or can be compensated) that it'll score in THIS game?
Originally Posted by stinglikeabee View Post
Do you even need to pick them up?
<snip>
You may find that picking frisbees up is not worth the time and effort.
Seriously? You seem to have concluded that it will be difficult to pick up frisbees, the floor won't be littered with them, and the cruise back to your feeding station will be both fast and easy.
I am sorry but I have to disagree on all points. Teams that can't pick up won't be in the top 1/3 of all teams.
Unread 05-01-2013, 22:20
protoserge's Avatar
protoserge protoserge is offline
AKA: Some call me... Tim?
In all my time in FIRST, I have learned to never discount a single game play methodology when discussing how to play the game.
Unread 05-01-2013, 22:24
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
When I throw a disk upside down (a scoober) I can normally get the disk to travel 15-20 feet strait. But there is often much wobble on its way there.
Taken from Wikipedia itself
Upside-down
A disc thrown upside-down has a very different flight path than one thrown right-side up. The lift force does not enforce stable flight as it does on a right-side up disc, resulting in a more of a parabolic arc in flight. As with a right-side up throw, however, the flight path of the disc will curve toward the lower edge. This banking effect is most pronounced when the disc is at a 45-degree angle, and less pronounced when it is near-vertical, or near-horizontal.
Gyroscopic precession causes the disc to rotate toward horizontal through its flight path. Unlike a right-side up throw, however, an upside-down disc will not precess toward a stable flat state, and will in stead oscillate past horizontal and begin to bank in the opposite direction. This shuttlecock-like effect is known as "helixing", and is generally avoided due to the difficulty in controlling a helixing flight path. For this reason, an upside down throw is typically released with either clockwise rotation and the left edge up, or counterclockwise rotation and the right edge up. The longer the disc is expected to remain in the air, the closer to vertical it must be at release to avoid the helixing effect.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 05-01-2013, 22:27
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
In my opinion, when thinking about not designing with the ability to pick discs off the ground, there will be at least 1 extremely successful robot that isn't designed to pick discs up(much like 1503 in 2011). However, I believe that the majority of teams that can't pick up off the ground will have little success.
Unread 05-01-2013, 22:30
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
I agree that scooper shots are much more wobbly and less stable than a normal back or forehand, but also remember that when we toss discs, the grip, flick, and arm motion all come into play. Depending on how a robot scores discs, the orientation may or may not be as critical.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 05-01-2013, 23:10
Jedward45 Jedward45 is offline
FRC #2220
Jedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant futureJedward45 has a brilliant future
I would not be so quick to rule out feeder-fueled bots. This game is a different animal than Logomotion or Lunacy.
The restrictions this year on entering game pieces changes that dynamic. Because frisbees cannot be thrown until last 30 seconds (when pyramid climbing likely reduces frisbee demand), the only remaining frisbees (excluding feeder frisbees) are the 28 initially on the field. Splitting this amount between two alliances, and assuming 50% are made, leaves 7 frisbees per alliance on the turf for robots to collect. Clearly, some of the remaining 90 white disks will need to be fed through feeder slots.
-Not to mention, frisbees may end up upside down or otherwise inaccessible
Unread 05-01-2013, 23:53
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
How do you figure? There are 45 alliance station discs across 3 teams. That makes for 15 per team. That's only one disc per team short of 4 loading/firing sessions of 4 discs per session. If you figure 20 seconds round trip per loading/firing session, that's 80 seconds of the match used up, plus 5 seconds for getting out of auton position and into loading position for the first time, leaving 35 seconds for hang and colored scoring. The absolute best teams will get one or at most two more firing sessions in. I think a majority of qualification matches will not deplete the alliance station supply of white discs.
Unread 06-01-2013, 00:12
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Originally Posted by apples000 View Post
Our team's been having some trouble figuring out how to pick up the frisbees from the ground. If we're picking up one in a corner, we'll need a sensor to tell if it's upside down then flip it if needed. Has anybody come up with a good way to flip/detect a flipped frisbee yet?
We were playing with the frisbees a lot today and we play Ultimate and frisbees rarely land upside down. Could be wrong, but that is what I see...
Faridodin "Fredi" Lajvardi KD7WKD
Unread 06-01-2013, 00:44
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
I hope that upside-down shooting is easy, so we won't have to automate disc flipping.
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
Unread 06-01-2013, 01:52
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
To be fair I feel like a similar battle cry was echoed in 2011 only to witness* one large exception.
What I would suggest to teams is to spend a little bit of time trying to figure out the scope and flow of the game.
The challenge is your enemy. Know your enemy. Week Zero (Saturday/Sunday/Monday) is not a time to determine your strategy, fixate on nonessential rules (someone asked me about bumpers today. Don't ask me about bumpers until a host of other decisions are made in conjunction).
If you can afford it, maybe go out and buy some discs, construct makeshift obstacles as stand ins for the pyramids. Get with a team of students on rolling office chairs or push around some old robots on some carpet with all of these elements to feel out the game. You think about a lot of things when you become an active participant when creating a scenario based off the game. You get a sense of the game.
For example, teams will easily fall victim to the misconception that the field area is roughly equivalent to the Louisiana Purchase. If you take time to create a tactile or even make good use of the virtual simulation, you will find the "laws" of the game. The laws of the game are played out in the nature of the challenge and are not written in the rule book (like the field littered with more discs than an unkept gym closet). Discovering the laws after your robot is locked up does not a successful season make.
This would all possibly be better addressed in the general strategy thread we have already, but you can't steal second base if you haven't even left the batter's box.
For now, get some sleep for me while I wish you all good luck!
Unread 06-01-2013, 02:08
wasayanwer97's Avatar
wasayanwer97 wasayanwer97 is offline
Take from the best, invent the rest
AKA: Wasay Anwer
FRC #0668 (The Apes of Wrath)
wasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant futurewasayanwer97 has a brilliant future
Though teams who have tested seem to report otherwise, it would seem that even if upside down discs didn't fly well, it would be easy enough for a shooter to just send it into the low goal for a quick point.
They are relatively easy to flip over though. Rolling a cart over it often flipped it back over. Perhaps just driving over one might do the same? You'd have to be careful for warping though...
Unread 06-01-2013, 02:13
Joon Park's Avatar
Joony13
Team Role: CAD
In my opinion, the orientation of the Frisbee, either during launch or in flight, doesn't really matter if you're doing anything in the realm of less than 2ft. But I wouldn't really consider that "throwing," more of "lobbing" the disc.
If you're actually considering successfully and accurately throwing the disc over some significant distance, I can't imagine the discs being oriented any other way than right side up and being give a whole lot of spin: the way they're meant to be thrown.
Unread 06-01-2013, 02:42
run the trap!!!
Team Role: Human Player
(The real question......
....which I was hoping this thread would answer)
Who has tried driving over flipped/rightsideup disks?
-Philip J. Fry
Unread 06-01-2013, 02:47
Racer26 Racer26 is offline
Oh 1503, feel like showing Don your 2011 results? I seem to recall the same arguments being raised about your robot, and you have 2 more Blue Banners to show for it.
Don, I wouldn't be so sure. There's 51 DISCS in the ALLIANCE STATION. I think most teams won't be able to reliably hit their 17, never mind be able to pick up off the floor in a reliable manner that is efficient for feeding their shooter, within the new reduced robot envelope.
I MIGHT actually go so far as to say that many of the topmost teams won't have floor pickup. Throwing frisbees is a much different animal to throwing compliant things like foam balls. I think the robot-fired full court shot will play a significant role this year. If I can park my super-reliable full-court shooter in front of a FEEDER STATION, and just fire all 51 DISCS into a goal from there, I'm gonna win most Qualification matches.
