Go to Post The strive for the Chairman's award is by far more important than the award. - Pavan Dave [more]
Unread 05-01-2013, 14:08
turtleman turtleman is offline
Captain/ Programmer
AKA: Carlos Jimenez
FRC #4369 (Brick City Bots)
turtleman is an unknown quantity at this point
That cRIO simulator mentioned at Kick-Off
You know, the one mentioned with the new changes along with the game simulator.
I was wondering if that was a website or something, as I'm not seeing anything like it in the KoP. Anyone mind helping me out? (put in programming directory as it has to deal with it...sort of.)
Cav Pride
Unread 05-01-2013, 14:10
mocibot's Avatar
mocibot mocibot is offline
FRC #1829 (Carbonauts)
Team Role: Student
mocibot is just really nicemocibot is just really nicemocibot is just really nicemocibot is just really nice
Re: That cRIO simulator mentioned at Kick-Off
From my understanding it's in LabView, not sure if it works with C++ or Java.
Good luck, stay safe, learn new things, and have fun!
I'm a student, because I don't fit in any one category.
Unread 05-01-2013, 14:36
bscharles's Avatar
bscharles bscharles is offline
Booyah
AKA: Brian Scharles
FRC #0930 (The Mukwonago BEARs)
bscharles will become famous soon enough
Here is the power point from our beta test presentation that we did a few weeks ago. Our team tested the LabVIEW software, including the simulator. Basically, when you create a new LabVIEW project, you get the option to choose a simulated robot. Then you develop your code as usual, keeping in mind the options available on your robot. These can be found in Robot Simulation Readme.html document in the My Computer section of your robot project. Once you create your code, you go into robot main, right click the box in the lower left, and change the target to My Computer. Then, press the white run arrow in the top bar, and it will launch a simulation that runs just like your regular robot. Make sure you use a decent computer (so don't try it on your classmate).
The first file is a word 2007-2010 file, the second one is word 97-2003
Unread 05-01-2013, 22:48
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Well that's unfortunate. We were so excited for the ability to program without a bot.
Back to unit testing, I guess.
Unread 05-01-2013, 22:50
ctccromer's Avatar
ctccromer ctccromer is offline
Animus
AKA: Tucker Campbell
FRC #3753 (Bulah Bots)
ctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to allctccromer is a name known to all
while we're on the topic, I have a question too
My team is under the impression that we need an autocad model in order to use the simulator (and if that's the case, it's pretty useless for us). Is this the case, or can I test the code without a custom model and such?
Team 3753 BulahBots
Unread 05-01-2013, 23:00
jvriezen jvriezen is offline
FRC #3184 (Burnsville Blaze)
jvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond reputejvriezen has a reputation beyond repute
Out of the box, you get some generic robots on a field that has some bumps and a bridge like in 2012 (thought not the same geometry) Also a loose ball on the field. You can choose arcade or tank drive with or without an arm for the generic bots.
John Vriezen
FRC, Mentor, Inspector #3184 2016- #4859 2015, #2530 2010-2014 FTC Mentor, Inspector #7152 2013-14
Unread 05-01-2013, 23:54
josh.pruim josh.pruim is offline
FRC #4014
josh.pruim will become famous soon enough
I did also hear about the cRIO sim at kickoff, and I was so excited to finally be able to code without the bot and get exact results. However, a few weeks ago, I had found this nice library - http://code.google.com/p/frcjcss/ - I'm still unsure about C++ sims, but knowing the FRC community, there's one out there. If I stumble across one, I will be sure to report back here.
Unread 06-01-2013, 06:49
The simulator shouldn't really have been called a cRIO simulator or a vxWorks simulator. It is a robot simulator. It runs your WPILib code on the PC and that communicates to the generic NI Robot Simulator containing a FIRST specific model that is approximately a kitbot with lots of sensors. At the moment, only LV has the communications integrated into its WPILib implementation.
Greg McKaskle
Unread 06-01-2013, 11:59
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
Likewise for us. If anyone is interested in more documentation, here are some of our beta testing results:
http://team1912.com/beta_testing.html
The two most useful would probably be the presentation itself and possible the Task 4 (Simulator) description if you would be interested in reading a more rambling thought process
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 06-01-2013, 18:34
bscharles's Avatar
Booyah
AKA: Brian Scharles
If anyone has any questions, I would be happy to answer them, since I did a lot of work with the simulator in beta testing. While it doesn't completely replace your robot, it is nice to be able to make sure your code runs properly and doesn't have any errors, as well as testing logic, etc.
